Detailing Stock Engine-Bay
Old Jan 6, 2007 | 12:36 PM
BelgianEvo's Avatar
Hi there,
I have a stock evo IX, and i would like to do some detailing in the enginebay.
For example :
- Polishing the aluminium air-hose next to the batterie.
But are there some other things that can be done to make the bay look nicer?
I mean with the stock parts that are in it now, without buying new things.
I've seen a polished topside of an intercooler, but is that possible with the stock one?
All propositions welcome
Ben
Old Jan 6, 2007 | 12:41 PM
Evoryder's Avatar
mothers mag polish ... with alot of work u can bling out the stock intercooler...
and ther upper pipe...also tire shine...spray adds shine to the stock plastic components...
Old Jan 6, 2007 | 12:43 PM
BelgianEvo's Avatar
Are there any other parts that can be polished after removing the paint?
I presume the IC is black paint and underneeth there is aluminium?
Old Jan 6, 2007 | 05:50 PM
ries's Avatar
anything aluminum can be polished, itll just take a lot of elbow grease
Old Jan 6, 2007 | 05:59 PM
smokeyonline's Avatar
You can polish your fenders and your hood
Old Jan 6, 2007 | 06:05 PM
Kerr's Avatar
Fomer Vendor
I think I have seen a polished stock strut bar before, or chromed, whatever it was, it was shiny.
Old Jan 6, 2007 | 06:09 PM
dafoe69's Avatar
I was wondering about this too except I just wanted to know the safest way to clean the engine bay cause after two years it is pretty funky under there. My friend said to hit it with water and avoid the coil packs and such but that sounds shady.
Old Jan 6, 2007 | 06:18 PM
evoixbri's Avatar
what is there to detail? and how do you go about doing that?
Old Jan 6, 2007 | 06:36 PM
fryedchikin's Avatar
Fill a spray bottle with about 2oz of Dawn and fill up with water, use with a soft 3in paintbrush to clean the engine bay and rinse with a slow stream of water from a hose. Using this method you can avoid getting excessive amounts of water in the alternator and such. I have found this to work better than any of the engine degreasers you can buy, plus its nowhere near as harmful if you should overspray onto the paint..worst it can do is remove some wax.
Old Jan 6, 2007 | 06:44 PM
Evoryder's Avatar
run the car right after you've hosed her down...let the car idle for a minute or two...
SLVRNBLK
Feb 28, 2016 03:06 PM
Mike@Mynes
Dec 9, 2008 04:09 PM
SLVRNBLK
Aug 24, 2008 06:47 PM
EVO8LTW
Mar 31, 2006 01:18 PM
Soon2BEVO
Nov 15, 2005 06:14 PM
