Quote:
when did you get this work done? was it under the 36,xxx mile part or some other part of the warrantyOriginally Posted by scottatayamaha
I got my done under warranty, he said that the gear was highly worn. I dont know much about transmissions. But you should look into it.
Quote:
I have had this noise with TWO different clutches. The first was the Exedy Hyper Single, now the Exedy organic with a stock flywheel. I find it hard to believe that the clutch install was botched both times. What would cause this noise, shudder, to begin with?Originally Posted by joseph k
i dont know about rebuilding the tranny. i have a Exedy Hyper Single Organic disc, and a gruppe-s lightened flywheel. i have the exact same noise that you have, and only if i leave it in gear while not accelerating. i.e. engine braking. so, i would disagree w/ the transmission having problems. i never had this sound before the clutch and flywheel. i feel as though it has something to do with the people that installed it(TOPSPEED). i had another guy give it a once over, very qualified tuner and if he wants he can speak up, he advised to be wary because something about it didn't seem right. i still get the sound and sometimes a little clutch smell, and i am not talking about launching the car, when i reverse. it may be normal, but not everyone has it going on.
I just want to really figure this out. I don't want bigger problems to arise from this later when I can take care of it now.
Thanks for the replies.
Quote:
Car is in gear, under no acceleration.Originally Posted by joseph k
whoa, i just noticed you said when the clutch is out. do you mean in gear with the clutch engaged? if so i have the same problem. if your getting the problem with the car not being in gear i am not sure what it may be.
Got it done at 24,000miles and the car now has 32,000 miles on it.
Quote:
would that be covered under the 36,000 mile 3 year part or the 5 year powertrain part? that is what i meant to askOriginally Posted by scottatayamaha
i have no idea what is causing, sorry to say. it does seem almost like it is slowing the car down, maybe dragging something behind the car like a parachuteOriginally Posted by revvin9k
I have had this noise with TWO different clutches. The first was the Exedy Hyper Single, now the Exedy organic with a stock flywheel. I find it hard to believe that the clutch install was botched both times. What would cause this noise, shudder, to begin with?I just want to really figure this out. I don't want bigger problems to arise from this later when I can take care of it now.
. seriously though i will not know for sure until spring because i turned the boost down for the winter and won't be turning it back up until the spring. i will definitely know whether or not it has affected the performance because i will also be getting it tuned for the meth kit going on in the spring. i had it tuned back in may of last year by Shiv @ Dyno4mance, and the tuning will be done at the same place on the same dyno so the numbers should be the same. g/l man, and if you figure something out let me know.Quote:
It does slow the car down, I can feel it. Originally Posted by joseph k
Are you still driving around with this issue on your car?
Quote:
good to know. did you have the stock clutch in or an aftermarket one. i am just wondering how picky they would be. thanksOriginally Posted by scottatayamaha
50,000 powertrain
for like the last 4-5000 miles.Originally Posted by revvin9k
It does slow the car down, I can feel it. Are you still driving around with this issue on your car?
Quote:
Do you recall when it started occuring? Sorry for all the ?'s.Originally Posted by joseph k
Quote:
I gotta figure out what could be done wrong to casue this during a clutch install. I bought the car from a friend who had the clutch installed at a local shop, not AMS. Originally Posted by joseph k
i know exactly when, it was after the clutch and flywheel were installed at TOPSPEED
That same shopped caused me to sell my old Del Sol due to "over honing" my bottom end, and the over spray all over my exterior/interior. I have my doubts.
But if something was done "improperly", don't you think it would've been noticed during the next clutch install?
Quote:
Had the stock clutch at the time, now I have a ACTOriginally Posted by joseph k
Former Vendor
I just had an act clutch put in my 04 EVO. I am getting the same strange noise at deceleration. It started making that noise right after the install. I get some vibration in the clutch pedal but I just put 200 miles on the new clutch, not even broken in yet. I also had a 50/50 mix of BG synchro put in also. I have no idea why it's making all the noise. I'm wondering if it's because of the BG synchro.
