back from RRE
Old Jan 18, 2007 | 05:18 PM
ct9a_mr's Avatar
Everything sounds fine especially if RRE tuned if for you.
If you are really worried get a taxtrix cable and look for knock yourself.
You don;t need headstuds at your level of mods.
Old Jan 18, 2007 | 05:50 PM
Z-Ball's Avatar
Originally Posted by wirespeed
I was tuned by Scott and I spike to 24. Been running for about 6 months like that.
good to hear that. yea i guess i'll just leave it and wait till the cold weather goes away and see what happens. but i think i will still look into getting the studs
Old Jan 18, 2007 | 05:52 PM
Z-Ball's Avatar
what gears do you spike that in? and what do you taper down to
Old Jan 18, 2007 | 06:03 PM
dsevo's Avatar
Scot tuned my car as well, and trust me, you have nothing to worry about. Chances are your guage reads high, because my E-Boost 2 says I'm running 24 lbs. on pump while my medical grade MAP sensor says I'm really running 21 lbs. Scot tunes relatively conservative, and the last thing he wants is for you to blow your motor and hurt is rep. Also, I wouldn't worry about head stufds unless he told you to install them, becuause he tuned your car knowing exactly what mods it has, and he would tell you if it needed something.
Old Jan 18, 2007 | 06:08 PM
Steiner's Avatar
There is a huge difference between a spike to 25lbs and actually holding 25psi. You're fine. You should have plenty of trouble free miles ahead of you. Now go get some cams and some cam gears and start enjoying the other half of the power band.
Old Jan 18, 2007 | 06:16 PM
Z-Ball's Avatar
alright thanks for the input
Old Jan 18, 2007 | 06:18 PM
Z-Ball's Avatar
you think i should cams and cam gears next? i was thnking that or the fmic
Old Jan 18, 2007 | 06:26 PM
scb1999's Avatar
I've had problems with socalEvo in the past. Just have a friend or someone who is registered e-mail the moderator.
Old Jan 18, 2007 | 07:19 PM
statix's Avatar
Originally Posted by Robevo RS
you have head studs? with 25 psi i would get it.only $90 .
You dont need head studs.
Old Jan 18, 2007 | 08:27 PM
Steiner's Avatar
I don't think a bigger intercooler will yield significant gains until you're in the 400whp range. I haven't done a lot of research on it though but it seems like more of a cosmetic improvement. Certainly won't hurt performance though. On the other hand a set of aftermarket cams, cam gears, and a fresh tune will put a permanent shat eating grin on your face.
Old Jan 18, 2007 | 11:57 PM
Z-Ball's Avatar
it wont hurt tho if i lower the boost a 1psi or so right?
Old Jan 19, 2007 | 12:01 AM
TogueMonster's Avatar
Originally Posted by thisxguy
if scott gray told you that, then you should believe him. i have yet to hear bad things about him.
Scott Gray told me to jump off the Golden Gate bridge. I leave for San Francisco tomorrow morning.
Old Jan 19, 2007 | 12:28 AM
Z-Ball's Avatar
yes
Old Jan 19, 2007 | 07:33 PM
wirespeed's Avatar
3rd. 21-22psi
Old Jan 19, 2007 | 07:42 PM
EVO8emUp's Avatar
New head sutuds? If a 25psi spike lifts your head, your head was not installed properly. If it doesn't knock, you should be fine.
