back from RRE
Old Jan 20, 2007 | 03:12 AM
  #31
riceball777's Avatar
your really shouldsent be boosting past 20psi on 91 octane so cal gas
mine is ste at 30 pis and i taper to about 18psi by redline
Old Jan 20, 2007 | 06:11 AM
  #32
steevo's Avatar
Originally Posted by Z-Ball
it wont hurt tho if i lower the boost a 1psi or so right?
No, that won't hurt. If your losing sleep over it, go ahead and turn it down 1psi. Better safe than sorry.
Old Jan 20, 2007 | 08:22 AM
  #33
Smogrunner's Avatar
i want to trust the tuner, but its just that after all the things ive been reading since ive got the evo is not to boost 25psi
Get a Tactrix cable for $90 and their Logging Software for $20. Then go out and do a log. Look at the results and you'll know. Keep in mind that it has been butt-cold lately and because of that you will see higher boost as a result. When the weather warms up you'll probably drop by a 1 or 2 psi. Scott is definitely one of the top 10 in the country for tuning Evos, so you should be just fine.
Old Jan 20, 2007 | 08:33 AM
  #34
*sam*'s Avatar
+1
The only reason your spiking to 25psi is the past couple month in socal the weather is cold 30-40 degree in the morning and evening, but you might get the occasionally high 60 degree in the afternoon. MBC seen to fluctuate during weather changes so imo your safe. Like smoggy said when it's summer time your PSI will decrease.
Old Jan 20, 2007 | 11:21 AM
  #35
05-EVO-GSR's Avatar
Z-Ball,
Your car is fine. Listen to Scot Gray, not the internet.
Old Jan 20, 2007 | 01:13 PM
  #36
slow_evo's Avatar
Originally Posted by 05-EVO-GSR
Z-Ball,
+1
My car spikes to 26 psi (in 5th) and I'm bone stock!
Old Jan 20, 2007 | 01:34 PM
  #37
Gsr Mann's Avatar
Trust your tuner I have heard only good things about gray.
Have you done any night runs when the air is more dense if it doesn't spike beyond 25psi then ure ok
Old Jan 20, 2007 | 08:21 PM
  #38
rjdevo9_mr's Avatar
how much did you pay at RRE for your tune?
Old Jan 20, 2007 | 09:31 PM
  #39
Z-Ball's Avatar
200
Old Jan 23, 2007 | 10:15 PM
  #40
Mike W's Avatar
You can always contact Scot and RRE in the same way you got a hold of them to do the tuning I think :-) I think they can answer your questions and concerns best.
Mike W
Old Jan 26, 2007 | 08:48 PM
  #41
degradated's Avatar
What does it spike to and hold in 5th (and 6th if applicable)?
Old Jan 27, 2007 | 06:35 PM
  #42
skiracer's Avatar
Dr. Gray tooooned me as well
misterevo8
Dec 4, 2012 05:32 PM
evillancer06
Dec 21, 2009 07:14 AM
Chamama
Feb 28, 2008 05:57 PM
EvoDan2004
42
May 27, 2007 04:48 AM
Noize
28
Jan 30, 2007 07:41 AM
