Ripped off... Need some input
Old Jan 26, 2007 | 12:43 PM
App420's Avatar
No longer
Old Jan 26, 2007 | 12:50 PM
NIevo's Avatar
Does this Vendor perhaps start and end with a R? Lol...had to throw that out there.
Old Jan 26, 2007 | 12:53 PM
Schuyler's Avatar
4G64 - isn't that the spyder GT engine?
Here's the spec differences - just get a caliper and measure the engine and it should answer your question for ya.
http://4g64.150m.com/turbo.html
Edit: Of course since it's supposedly "stroked" the measurements will be different from a stock 4g63. IMO don't accept anything you buy with ANY identifying marks scraped off! It could be stolen, etc.
Old Jan 26, 2007 | 01:04 PM
lexat20's Avatar
that was my first thought too.
Good luck man I hope everything works out for you.
Old Jan 26, 2007 | 01:06 PM
boostinjuice's Avatar
i was thinking.. hm does it end in R?
Old Jan 26, 2007 | 01:10 PM
App420's Avatar
maybe...
Old Jan 26, 2007 | 01:15 PM
chongo's Avatar
that sucks man good luck
Old Jan 26, 2007 | 01:19 PM
saiyanzzrage's Avatar
Damn Ken, I didnt hear about this, good luck bro!
Old Jan 26, 2007 | 01:26 PM
DRFTKNGG's Avatar
The 4G64 which is 2.4 liters is found in the 00' and up Galants, outlanders...the evo head bolts right up to this. So even if it is a 4G64 it will work. Not a bad mistake if this is so.....factory 2.4 liter iron block...fits right in the evo...?
Old Jan 26, 2007 | 01:31 PM
DRFTKNGG's Avatar
Gasket should'nt hang into the combusion chamber though.
Old Jan 26, 2007 | 01:45 PM
App420's Avatar
If I decided to keep this, which is my only choice at this point, is it safe to assume that if I buy a head gasket for a 00+ Galant, that it will fit properly? I would go towards an HKS one, if thats the case. I think a 1994 Galant was a 4g64 as well, will a head gasket from that fit?
Old Jan 26, 2007 | 01:48 PM
DRFTKNGG's Avatar
^^^Check it out forsure. I thought the 4G64 was 2000 and up? But if not, measure the cylinder and then go to mitsu, ask the parts guy to take a look at one inhand.
Old Jan 26, 2007 | 01:49 PM
joeymia's Avatar
line up your water pump on the block. if it doesn't fit right then you got a 4g64.
DRFTKNGG's Avatar
Head gasket must clear bore. It will work, but for a limited time untill the gasket gets baked enough to give up.
Old Jan 26, 2007 | 01:51 PM
DRFTKNGG's Avatar
.....here you go, Joe tell em whats up. Mr.4G64.
