Evo 9 MR on Motec M800 => anti-lag launch
that's a USDM M800 with CAM Control enabled. We will be able to source Aussie-Spec M800 (Gold Box) and PnP units in the near future. Once the channel is established, we will be able to do group-buys on Motecs
2006 Mitsubishi Lancer Evolution IX MR
4G64 Built Short Block
Cosworth 272° Duration 11.0mm Lift
Cosworth Head Studs
WORKS Valve Springs & Ti Retainers
GT35R Turbo
MoTeC M800 ECU
Greddy 24V Intercooler
Blitz SUS Air Filter
Greddy Titanium Racing Exhaust
Carbonetic Twin Carbon Clutch
E.T.: 11.43@128MPH 1.99 60'
Cosworth Head Studs
GT35R Turbo
MoTeC M800 ECU
Mods list for the car:
2.4L 4G64 Mynes-Built Short Block
GT35R Turbo
Blitz Induction Cover
Test Pipe
Greddy Titanium Exhaust
Cosworth 272 11.0mm Camshafts
Works Valve Springs
Works Titanium Retainers
Carbonetic Twin Carbon 1,350KG Clutch
Walbro Fuel Pump
780cc Fuel Injectors
Motec M800; 518whp; 450wtq
27PSI~26PSI
Sunoco GT Plus Unleaded 109
It's the same car that we used to test the Cosworth CAMS:
https://www.evolutionm.net/forums/sh...=233547&page=1
And it's the same car that ran here:
https://www.evolutionm.net/forums/sh...=242735&page=1
GT35R Turbo
Test Pipe
Works Valve Springs
Walbro Fuel Pump
27PSI~26PSI
GT35R Turbo
Test Pipe
Works Valve Springs
Walbro Fuel Pump
27PSI~26PSI
GT35R Turbo
Test Pipe
Works Valve Springs
Walbro Fuel Pump
27PSI~26PSI
780cc injectors? You haven't ran out of fuel yet!? How long would you expect the turbo to last with the ALS setting you have it at? To be completly honest that is some of the coolest sh|t i have ever seen but nobody ever uses ALS b/c of how much it shortens the life of the turbo and driveline parts. Great job on the car none the less!
For the next three Fridays, we got rained out here in Phx... the track is only open on Fridays and it rained on three Fridays in a row
so we said fu**it and did some runs on the dyno. It did 11.2 with a 1.66 60'... and we know from experience that actual 1/4 is about .5 second faster... so with a good launch on the track, the car should be in the 10.90 range (or faster) at that trap speed.It's raining here in Phx right now, but hopefully the rain will stop by Friday night
Like i said before, we are simply trying to get some benchmark figures for this combo to give our customers an idea of what to expect out of their builts... Our Evo 8 Drag Car is nearing completion... once that's done, then the Evo 9 will be reserved for road-racing only... the 8 is gonna ROCK even harder
