Evo 9 MR on Motec M800 => anti-lag launch
The Motec simply allows more control parameters than the stock ecu. Let me put it in computer terms...
Same hardware configuration: cpu, ram, mb and hard drive... if you put Windows on it, it might run slower b/c it takes up more resources; and if you put Linux on it, it might run faster b/c the sw is more efficient in managing it's resources. I used to dual-boot on my laptop with Windows and Linux... on 512mb of ram, it still runs slow in Windows, but that was more than enough for the Linux side...
more control, more parameters, and likely more power.
Disadvantage:
- no knock control
- no pre-defined maps (the tuner has to build the map of your car from SCRATCH).
dunno... it depends on how hard you want to push your setup... there's no reason to suspect that this setup is going to last longer or shorter just b/c it's running Motec.
On the roadrace courses, we don't use the anti-lag at all... it all depends on what you want to built your car to do... we are simply showing some of the capabilities of our shop car and the Motec ecu.
We should have some old videos of the Shop 8 (from last year) shortly.
cheers.
mike
