Washer fluid freezes and clogged the hose.. HELP?
Old Feb 6, 2007 | 06:21 PM
fq340's Avatar
jeez i just found out that this is an even worse problem.. i tried to pump out all the old fluid and replace it with new fluid... i could only pump out 1/4 of the tank. then i noticed that its not the hose thats frozen... its the 3/4 tank thats frozen to solid... should've replaced the old fluid earlier...
Old Feb 6, 2007 | 06:23 PM
3SgteGuru's Avatar
Originally Posted by heavens turbo
or some coolant, (anti-freeze), just not too much
HAHAHAHAHAHA . No please don't do that
Old Feb 6, 2007 | 06:24 PM
3SgteGuru's Avatar
Originally Posted by o-townFLA
DONT put alchohol in your tank. It'll dry out your lines...
umm that y I said Water too.
Old Feb 6, 2007 | 06:26 PM
3SgteGuru's Avatar
pump out what you can and Fill with Pretty much straight rubbing alchohol. When it melts, pump some out and add a little water.
Old Mar 8, 2007 | 06:14 AM
Chukee_R's Avatar
I had the same problem this morning.
I washed my car over the weekend and haven't driven it since. I'm wondering if some water got in the sprayers and froze.
I'm driving 2 and a half hours tonight so I'll give it a try then and see what happens. Hopefully the engine heat will be able to thaw it out.
Old Mar 8, 2007 | 05:44 PM
silverofs's Avatar
all washer fluid is is methanol just put a good concentration of that in there we just have a 55 gallon drum & we mix it heavier for winter & not so much for summer, there is to much water in your mixture is all.
Old Mar 8, 2007 | 05:52 PM
evrblazin's Avatar
Next winter just buy Rain-X brand which is rated to -25 F. Done.
Old Mar 8, 2007 | 06:15 PM
Chukee_R's Avatar
Warmed up today and washer fluid spray out just fine!
Old Mar 9, 2007 | 05:48 AM
SlowCar's Avatar
this mixture table is good for water/alcohol injection, good for windshield fluid too
http://www.ashland.com/pdfs/technica...sh%20Point.pdf
Sheasta
Nov 27, 2015 01:26 PM
jrainwater
Mar 18, 2014 07:48 AM
Beardly P
Mar 17, 2011 06:35 PM
projekX
Jul 6, 2009 03:21 PM
Seitz
14
Jun 26, 2006 03:06 PM
