Washer fluid freezes and clogged the hose.. HELP?
Old Feb 4, 2007 | 10:24 PM
fq340's Avatar
its been subzero for couple days here in the midwest.. i think my washer fluid hose is clogged by frozed fluid inside the hose because nothing come out from the nozzles even i have a full tank of fluid. i parked my car in the garage overnight but no luck because its too cold. if the washer fluid tank is not located in the trunk, i think it would never happen... HELP?
Old Feb 4, 2007 | 10:28 PM
Danny23's Avatar
Get you car parked in a heated garage for a few hours if you can. When you go pick it up to leave you should be good to go.
Old Feb 5, 2007 | 01:05 AM
Frenchy4g63's Avatar
Get the stuff for melting ice. I got some orange shlt that melts ice down to like -40 or something..
Get some and fill the bottle as much as you can, let it sit for a while, and it should be fine.
On a side note, yeah it's really f*ckin cold here. So cold accually that my classes were cancelled today. -12 right now with a -28 wind chill.. holy shlt..
Old Feb 5, 2007 | 05:47 AM
topnitroracer's Avatar
I have been watching out for this to happen to be again. It is -4 deg where I am at right now with a wind chill of -22 deg. It happened with my civic last year and oh man was it a pain. If you have room to add more fluid, try adding the de-icer washer fluid. This will still take forever but it starts to help. Put it in the garage and use a hairdryer and just leave it. Then try thawing the lines running up to the front. As more washer fluid melts replace it with more de-icer. The once you get it spraying, run the washer until you are sure you have flushed all the old stuff out. Good luck with getting it resolved.
Old Feb 5, 2007 | 05:54 AM
3SgteGuru's Avatar
poor some alchohool in it. And don't use washer fluid. Man I can't believe they sell that ****. Get a little dawn soap (like a teaspoon) and put that in your container, then fill it 1/2 with water and 1/2 with rubbing alchohol. That should clean your windows verry well and it won't freeze unless it gets down to like -20. and if it does get that cold put more alchohol than water.
Old Feb 5, 2007 | 08:52 AM
derangedazn's Avatar
I hope you put rubbing alcohol in it..I can see someone pouring tequila or vodka in their car.
"Dis iz for my homies..and dis iz for da Evo."
Old Feb 5, 2007 | 11:29 AM
heavens turbo's Avatar
or some coolant, (anti-freeze), just not too much
Old Feb 5, 2007 | 12:30 PM
EVO8emUp's Avatar
DONT PUT ANTI-FREEZE IN THERE!!!! Glycol is not for cleaning glass!
You can purchase fluid for extreme cold temps.
Old Feb 5, 2007 | 12:36 PM
Danny23's Avatar
Do that and all you will get is a slimy greasy windshield.
Old Feb 5, 2007 | 12:45 PM
Wont the soap foam it all up? A teaspoon of dawn now cleans about 5,000 dishes, does't it? j/k Most washer fluid is just too inexpensive to mess with anything else.
Old Feb 5, 2007 | 12:48 PM
Yeah no anti-freeze!
Use HEET if anything. It is methanol and is the ingredient in most washer fluids which keep it from freezing. The greater the methanol content, the lower the freezing point.
Old Feb 5, 2007 | 04:55 PM
o-townFLA's Avatar
DONT put alchohol in your tank. It'll dry out your lines...
Old Feb 5, 2007 | 05:28 PM
DSMorBUST's Avatar
interested to know where you came up with this idea? never even heard of it b4... is that what youre doing to your evo? or have you done it b4? results?
Old Feb 5, 2007 | 08:23 PM
fq340's Avatar
so many different replys... thanks guys. i got like 3/4 tank of the blue washer fluid.. i just filled up the rest of the tank with the orange "ice melting" washer fluid.. i'll see if it'll work tomorrow. yes its still real cold... -9 here...
Old Feb 6, 2007 | 05:53 AM
cfdfireman1's Avatar
You can add a little methanol to get a more concentrated fluid the good stuff is about 33%. Don't buy the cheap stuff if you live in a cold climate.
