Aftermarket Head gasket?
Old Apr 9, 2007 | 06:36 PM
Jakeg97's Avatar
oem does the trick
Old Apr 9, 2007 | 06:39 PM
caLi4G63's Avatar
I can vouch for the HKS 1.2MM head gasket, I've had it for about 8k miles and I haven't had any issues. I installed it when I pulled of my head to do cams, valvetrain and the ARP head studs.
Old Apr 9, 2007 | 06:46 PM
mitsuorder's Avatar
Originally Posted by bttkcooled
evo 9 HG ftw
So the oem head gasket is compatible with the 8 block and head? I had heard that there are more coolant ports in the 9 gasket, which would make sense since the 9 is more detonation resistant. How many layers is the 9 gasket?
Old Sep 16, 2007 | 09:07 AM
MikSchultzy's Avatar
*bump*
I'm in the market for a head gasket as well. I've got an 03 Evo8. Doing head studs, valves, cams, prolly cam gears....
But I'm torn with all these different gaskets. Why should I spend $200 on an aftermarket gasket?
I do intend to do a slightly larger turbo as well (At least an Evo 9 turbo).
Old Sep 18, 2007 | 06:02 PM
Stewby's Avatar
1 x 1 = high risk of head gasket leak.
Old Sep 18, 2007 | 06:16 PM
ExViTermini's Avatar
someone show me an instance of one that has. I'd like to read the method and see why they had a failure.
I've done it about 5 times so far on diff cars, including my own. 0 problems.
Old Sep 18, 2007 | 06:29 PM
Bom's Evo's Avatar
If you want to lower your compression try an aftermarket one that shims it.
I had the HKS one that lowered the compression. It held perfect along with arp headstuds.
I now have an OEM one now with the same headstuds working perfectly fine as well. Reasoning for changing was the big boys race cars use them with great success and I had to change the valvetrain.
Each time I pulled the head.
Old Sep 21, 2007 | 01:36 PM
RanEvo's Avatar
Originally Posted by dubbleugly01
that's an odd recommendation since AMS recommends sticking with the stock head gasket.
Don’t you EVER us a Cometic one! If you wish I will email you my pics’s, and you will know I saved you!
Old Sep 24, 2007 | 08:47 AM
kduncan01's Avatar
If you remove the head to change the head gasket do you need to take the head to a machine, or can you remove then reassemby everything with the new parts?
Old Sep 24, 2007 | 08:48 AM
kduncan01's Avatar
Post some up so we can all see!
Old Sep 24, 2007 | 10:58 AM
dudical26's Avatar
Originally Posted by Waz996
getting ARP head studs.. i think i dont wanna risk it, i'll go with the all bolts+gasket method, the old sure way..
wael
I agree with you on replacing the head gasket. I have heard lots of issues with oil dripping down the back of the block when people do the 1x1 method.
What is wrong with your cams that requires fixing?
DSPORT
Oct 13, 2015 01:41 PM
SavEVOIX
Sep 6, 2011 09:09 PM
EVIL-EVO-8
29
Jan 21, 2011 05:43 PM
raevo9
Feb 24, 2009 07:51 AM
