Help with MBC install
Old Feb 25, 2007 | 08:49 PM
Jakeg97's Avatar
Originally Posted by Chemwarrior
These are not the same instructions that BR says to use. They say to go from the wastegate actuator to the MBC and to cap off the wastegate.
either way will work
Old Feb 25, 2007 | 09:14 PM
SPANKED's Avatar
Good info...thanks
Old Feb 25, 2007 | 09:20 PM
chaotichoax's Avatar
here is the optional way of mbc install for those interested
Old Feb 26, 2007 | 04:51 AM
Chemwarrior's Avatar
I thought this was not the preferred method due to irregular readings.
Old Feb 26, 2007 | 04:52 AM
Originally Posted by chaotichoax
just curious which diagram did you use? the one I provided?
glad you have it figure out
Yes I used your first diagram that you posted. You were a big help. Thanks.
