got the evo dynoed!!! whoo
Old Mar 1, 2007 | 05:32 PM
  #46
Redfire's Avatar
It should peak at 1.4 bar and taper to 1.1 bar by high rpm. If you are somehow seeing 1.5 bar (21.75psi) at high rpm (7k), then that's a bit strange.
thank you. that is what i have been trying to say. now it hits 21-22 PSI and holds
Old Mar 1, 2007 | 05:34 PM
  #47
Redfire's Avatar
ok so this thread turnout useless. i either have people telling me that i did it wrong(even though i didnt even tune the damn car) and being given advice i didnt ask for. but to the guys that said nice numbers. thanx. and as for the other guys...oh well. i dont care
Old Mar 1, 2007 | 05:41 PM
  #48
KartaRailed's Avatar
Ok, good numbers, and warrtalon is not agreeing with you on the boost thing, he is just saying that that person's car is acting up. Unless you got your car used and it was acting up when it was new, than you ran 20.3 PSI stock. No way around it.
Old Mar 1, 2007 | 06:05 PM
  #49
evo_08's Avatar
did aniel install everything?
Old Mar 2, 2007 | 10:33 AM
  #50
Redfire's Avatar
him and goerge and bryce all worked on the car. they got it done fast!!
Old Mar 2, 2007 | 10:42 AM
  #51
Dead-Man Inc's Avatar
Awsome Numbers ! ..
now put on Cams + lower IC piping + FMIC and you are set to go big turbo ! ..
although u'll be having over 370 whp ..
Old Mar 2, 2007 | 11:03 AM
  #52
Kee1pride's Avatar
those are awesome numbers for only 22psi. congrats but even i run 24 psi daily without knock. you should crank it up 2 more lbs and you'll still be fine. looking forward to seeing your car at the meet next wednesday redfire
Old Mar 2, 2007 | 11:43 AM
  #53
saetern's Avatar
nice numbers, wish we had a awd dyno here for us to use
Old Mar 2, 2007 | 11:49 AM
  #54
thatsMR2u's Avatar
i still dont understand why it hit 15psi and tapered to 13.5 - stock turbo can make 15 psi and not taper at all- why u would run 15psi is beyond me tho
Old Mar 2, 2007 | 04:51 PM
  #55
Redfire's Avatar
cause its my low setting. i drive it everyday and i get badass MPG on the low compared to the high. why do u care so much?
nwa7265
Oct 16, 2012 07:19 AM
David Buschur
109
Mar 2, 2011 04:00 PM
DG Motors
Evo X Dyno Results
75
Jul 7, 2009 08:25 PM
storm_trooper
West Region
Jun 15, 2009 11:45 AM
TURBODAWG
73
Feb 9, 2006 08:38 AM
