Turbo Blue
Old Mar 24, 2007 | 12:08 AM
rocket motor's Avatar
I don't think that it will hurt the injectors, gas is gas. The o2 sensor might be a different story with the leaded gas. You could always use some e85 and that will clean out the injector for sure. E85 is cheaper too.
Old Mar 24, 2007 | 07:43 AM
Jeff_Jeske's Avatar
All leaded fuel is dirty.....on the exhaust side..... Like I said nearly all of the import racers in my area have been using it for many years. For the $90 a new O2 sensor cost I don't really worry if I have to replace one every two years. That being said I never have had to.
Old Mar 24, 2007 | 09:32 AM
madmax199's Avatar
You should not have any problem with your injectors, I use some good injector cleaner in a full tank every six months running 100/110 mix (110 leaded). O2 sensor like everyone else said should in theory go faster but no one that I know have had one go yet because of running race fuel on the evo. If you have a cat, leaded fuel will clog it up pretty quick( a year of constant use I guess). If you are running 104 only when you go to the track I would not even worry about all that stuff.
JRR
Jan 10, 2024 01:55 AM
dennisgrish
Dec 22, 2016 09:19 PM
dennisgrish
Nov 14, 2016 02:33 PM
dennisgrish
Nov 7, 2016 02:30 PM
LVLANCER
Lancer Aftermarket Forced Induction Tech
10
Sep 21, 2010 08:29 AM
