Problem with my Zero Lift Kit (Front air dam)
Old Dec 8, 2007 | 02:03 PM
Wheelhaus's Avatar
Interesting, I might do that... The plastic piece is broken so I may remove the rubber dam entirely and fab some metal brackets instead so the front bumper doesn't droop or anything.
Could you just jack the front end up and take some pics so I understand exactly what you did? I just need to make it look "not broken" if I can't replace the parts.
Old Dec 8, 2007 | 02:12 PM
ducker's Avatar
The front rubber was also ripped off my undertray. I just used a bigger bolt on the broken section.
When u take the whole undertray off u will see there is like 2 inches of it that goes ABOVE the very bottom of the bumper. U drill and bolt the L-brackets up to that. So when u put it back on the whole undertray is supported by the L-brackets.
I would have to pull mine off to show u. I will if ya need me to.
But, if ur gona sell the car why even worry about it. Highly doubt anyone will even get down to the ground, and look at it.
Old Dec 8, 2007 | 07:35 PM
gixxer6's Avatar
Originally Posted by savaho
Take the **** off. You'll never notice it (performance wise) gone.
ya after that take off your turbo..you wont notice it either (performance wise)
Old Dec 9, 2007 | 10:04 AM
Adrenaline718's Avatar
This is interesting. I bought my Evo IX MR used with 24k miles, and I did notice that it looks like the previous owner had hit a parking block or something, the underside of the front lip is mangled, and even the bottom few coils on the FMIC are bent a bit (maybe 1/8 of an inch or so, not much). If there is an easy way to fix this without replacing my front bumper assembly, I would love to know.
It's pretty cold here in Michigan now, and I haven't actually gotten under there to get a good look at it yet from that angle.
Old Dec 9, 2007 | 12:40 PM
Xolition's Avatar
Same thing I scraped my bumper once and it was all deformed. The problem is the screws holding it on are on a very thin piece of rubber, so when you scrape it they pull through and you can't fix it because there's not enough room to make another (non-ripped) hole. I'm considering taking mine off as well, stupid design.
Old Dec 9, 2007 | 05:33 PM
silverghost's Avatar
zero lift
Adrenaline has it right. This caused by parking curbs. The body clears but the chin spoiler does not. Once I stopped pulling up the the parking blocks the bending stopped.
Old Dec 9, 2007 | 07:12 PM
waynea's Avatar
part number
I have seen a couple of numbers, MZ380342EX-MZ575625EX
list from an accessory catalog
Airdam Extension Vehicles with 17-inch wheel
MZ575625EX
Please be aware of the possibility of interference with the road surface depending on the road
condition and driving condition since the ground height becomes 155 mm due to the application
of an extension.
Including MZ555004EX (Brake Air Duct)
Wayne
mikkellucci
Feb 15, 2017 08:50 AM
StreetGasm Maus
Feb 16, 2011 03:52 PM
pghdsm
Jun 11, 2010 05:10 PM
SophieSleeps
Mar 27, 2008 02:27 PM
SophieSleeps
May 8, 2007 03:59 PM
