Necessary to get another reflash changing from 91 to 93?
Old Mar 13, 2007 | 03:26 PM
Chemwarrior's Avatar
When I had my ECU flashed from Al I specified that I was using 91 octane. I made a mistake in that because we actually use 93 octane. Would that cause any loss of performance or cause the engine to not operate at its full potential that would warrant another reflash or am I just pissing in the wind?
Old Mar 13, 2007 | 03:28 PM
heSOshAdy's Avatar
I would think so.. that is a pretty significant difference we're talking about. Im sure the other more experienced memebers will chime in.
Old Mar 13, 2007 | 03:30 PM
chaotichoax's Avatar
a reflash would be in order to maximize the potential of the car
higher octane gas enables you to run more boost with less occurrence of knock
you'll be fine driving the car the way it is but I would assume your a/f with the two gases would be a bit different...if you can afford it get the reflash
if not your car will be fine just not as powerful as it could be
what psi do you currently run?
Old Mar 13, 2007 | 03:32 PM
I run the car at full boost hitting around 22 and tapers down to around 19. Off the top of your head what kind of performance am I missing due to this?
blackoutVIII
May 24, 2013 02:57 AM
The Emperor
37
Jul 9, 2004 06:20 PM
TwoMix9900
Feb 25, 2004 11:35 AM
Dale_K
West Region
Feb 22, 2004 12:08 AM
davidw333
May 19, 2003 11:11 AM
