Horrible drive home. need help please...
Old Mar 23, 2007 | 08:15 AM
  #31
shivaswrath's Avatar
it really does sound like you lost coolant over time and just overheated your engine/froze the block. . .the coolant hose problem was a recall for 2005's, came out when i got my car, and it was the first thing I had replaced. . .check and see based on your VIN if the recall was done for you. . .in either case, it sounds like you'll need a new block
Old Mar 23, 2007 | 08:24 AM
  #32
rcheung's Avatar
Originally Posted by Prestine8
i think the proper way to phrase this would be did you miss your shift. and no i didnt because i didnt try to shift.
Yeah even if you were going 80 and misshifted into third you'd be okay.
Old Mar 23, 2007 | 08:44 AM
  #33
fransevo's Avatar
Keep us updated.
Old Mar 23, 2007 | 11:39 AM
  #34
Drift4's Avatar
Sorry to hear that bro...I know it sucks...good luck.
Thats why before you buy a used car have a PPI (Pre Purchase Inspection) done, you may be out 150-200 dollars rather than
5000.00 - 10,000.00
Old Mar 23, 2007 | 12:59 PM
  #35
Prestine8's Avatar
5000.00 - 10,000.00
yep, good thing i'm still young and have plenty of time to learn from these events.
Old Mar 23, 2007 | 01:04 PM
  #36
CRX2EVO's Avatar
what's wrong with the hose?
I have an 05
Old Mar 23, 2007 | 01:07 PM
  #37
Drift4's Avatar
sorry for the OT, but your 202 C43 will smoke this car all day long, I am seeking a C36 of a good used
500E/E500 124 chasis
Old Mar 23, 2007 | 11:43 PM
  #38
evoone's Avatar
why don't you drop your car off at the mitsu dealer? they can tell you exactly what happened to it. i believe they can go into the ecu and check where the rpm's were before the motor let loose. that way you don't have to play the guessing game.
Old Mar 24, 2007 | 12:14 AM
  #39
flip_EVO's Avatar
wow... you shoulda wrecked the car when that thing started to
happen so you dont have to worry lol j/k
but seriously you should take them to the dealership
and find out. we all can guess what happened but you wont
find out what really happenned to your car if you dont get them checked.
Old Mar 25, 2007 | 12:37 AM
  #40
dbsears's Avatar
I wouldnt take it to the dealer. Half of them wont know what there looking at. Since its an 05 I presume you still have warranty and that will just give them a reason to void your warranty because I your mods, I have seen it done. I would take it to a good shop that is known to work on evos or specializes in evo's. Just buy a stock short block if you dont plan to ever go over 500hp, that would be the cheapest way. Dealer will tell you need like a whole new engine bay
Old Mar 25, 2007 | 08:37 AM
  #41
donmeca2020's Avatar
so the recall only effect certain 05s not all correct? i might get this checked out just in case.
Old Mar 25, 2007 | 03:51 PM
  #42
Prestine8's Avatar
yeah i was thinking the same thing. plus i'd have to get the car towed over to the dealership again, and for them to tell me that my warranty is void bc of mods is a waste of time and money. Luckily for me there's a shop around the block who does engine builds and specializes on turbocharged cars. So i'm in the process of ordering a new shortblock, and once it arrives i'm going to have them install it. I just have to make sure at the same time that my turbo etc. didnt get damaged.
Old Mar 25, 2007 | 06:35 PM
  #43
Sxhawnn's Avatar
why not do this. Put your car back to stock with your local shop and ASAP. Then take it to the dealership and tell them the engine blew up on you and that you want it warranteed. Its definitely worth a shot man.
Old Mar 25, 2007 | 07:01 PM
  #44
Kerr's Avatar
Fomer Vendor
plus the guys always have "got boost?" shirts on so they'd know a lot more then me.
Old Mar 25, 2007 | 07:03 PM
  #45
Stew's Avatar
Remove your mods, delete all mods you posted in this thread, and take the car to the dealer. Mitsubishi WILL SEARCH EVOM for your post and your mods if they are looking into warranty work on your car. If they void your warranty, drop me a PM. I have an arbitration case against Mitsu for the same situation and I may be able to help. As soon as my case is final I will be posting up my documentation and results.
Good luck.
