202mph EVO
Old Mar 27, 2007 | 10:48 AM
  #31
mike1023's Avatar
Originally Posted by Flyin EVO 2
His Evo 2 weighs 2700lbs with him in it, it has a DSM final drive, at 202 mph he told me he was around 9,000 rpm in 5th gear. This was on a 235/45 17 tire which has a 25.33" diameter. It's making around 800 whp on boost.
wat does the dsm final drive do for the car?
and i was at 8300 off the rev limiter in my car, but that was on DR lol. so i was around 180ish i believe.
Old Mar 27, 2007 | 10:51 AM
  #32
inco9nito99's Avatar
kinda newbie of a question, but how do you go about calculating the tire diameter to be 25.33 again? Figure for instance my situation, 275/45/17 tyre on a 17x9 38 offset wheel.
Old Mar 27, 2007 | 11:17 AM
  #33
blackevoguy's Avatar
Good to see he got the car back together, i talked to him a little over a week ago up at devo tuning he was bringing a bunch of parts up there for the car
Not to go off topic but the shearer kit on that car is a fine piece of work
Old Mar 27, 2007 | 11:25 AM
  #34
IfDontFITsPIT's Avatar
Wow... congrats....
Old Mar 27, 2007 | 01:19 PM
  #35
Sean03Evo8's Avatar
that is so sweet, 200 for a 4g63 im amazed. what kind of aftermarket parts
Old Mar 27, 2007 | 04:54 PM
  #36
xspsi4's Avatar
great job Mike, I am sure the supra guys are happy now Way to represent 4g power.
Old Mar 28, 2007 | 02:37 AM
  #37
Flyin EVO 2's Avatar
EVO's 1 thru 3 used a DSM style tranny. An Evo 8 tranny is geared similar to the DSM ratio, but the early EVO's have a shorter final drive than a DSM. This is great for the 1/4 mile in an Evo that has a built motor and a large turbo with cams to take advantage of high rpms. This sucks for a mile because 4th and 5th gear aren't as close ratios on the early EVO's. Because of the short final drive they put a taller 5th gear which sucks for high speed acceleration with such a huge rpm loss when shifting from 4th to 5th.
Old Mar 28, 2007 | 02:40 AM
  #38
The calculator is within this horsepower calculator web site. It's one to save in your favorites.
http://www.speedworldmotorplex.com/calc.htm
Old Mar 28, 2007 | 02:54 AM
  #39
Shearer Fabrications custom race header, Shearer Fabrications custom air to water intercooler, 70mm 42r, motor built by Class One in freeport, IL, Arias pistons 9.0 to 1, HKS 272 cams, Ford 70mm tb, Forster intake manifold, Head ported & polished by Head Dynamics in freeport, IL, Devo Tuning Twin Disc, Shep Trans, AEM engine management, 1600cc injectors MSD dis2 ignition, Porterfield break pads, HKS hypermax coil overs, Nitto 555r's, Kosei k1 wheels. Mechanic work done by Devo Tuning, tuning and driver Mike Reichen.
Old Mar 28, 2007 | 05:59 AM
  #40
mike1023's Avatar
aghhhh i see very cool thanks for the info, and also congratz on the 202mph.
if you had to say was it hard to get evo going 202mph in the mile? and you think ya can get it going even faster
Old Mar 28, 2007 | 10:29 AM
  #41
Vigo's Avatar
Will the Evo 9 transmission top out at 200mph at 9000rpm?
Old Mar 28, 2007 | 10:33 AM
  #42
Nez136's Avatar
thats awesome, congrates!
Old Mar 28, 2007 | 10:40 AM
  #43
mdosu's Avatar
it's cool, but I woudn't feel safe in that car going above 200...i feel like I would need to be in some carbon-fiber monocaque type car...
Old Mar 28, 2007 | 10:47 AM
  #44
Vigo's Avatar
Carbon fiber will shatter like glass. I metal body is safer.
Old Mar 28, 2007 | 10:52 AM
  #45
TiALSport's Avatar
not so much
