Tuning for 87 grade fuel?
If I were you I would not attempt to run 87 fuel. Even de-tuned it will most likely cause damage to your engine.
Besides the amount of power you would lose from that gas and the de-tuning would make owning an EVO almost pointless.
even when tuned correctly carbon buildup is major fast with 87 octane. compression would keep going higher with carbon build-up. now 87 with meth/water injection can work quite well. the meth/water will keep the combustion chamber clean.
