Stock DV and Buschur Intake
Old Apr 19, 2007 | 07:33 AM
yikez's Avatar
I just installed my new Buschur Racing intake on my evo ix. Loaded my new flash from Jestre Tuning and off i went. Now i know you are supposed to hear your DV a lot more with an intake, but is it really that loud? It's so loud that it sounds like my friends SSQ BOV while i only have the stocker. It also flutters a lot. Is this normal? i have a feeling this is just an installation issue or possibly just normal.
Thanks to Buschur Racing for excellent customer service and fast shipping.
Thanks to Jestre Tuning as well for super fast service and excellent customer service.
Old Apr 19, 2007 | 07:35 AM
scheides's Avatar
EvoM Moderator
Yup, it will be quite loud with an open element intake. There's no box for all of the sound to get trapped in! Did you get the intake pipe as well? That make it loud too, since the sound waves will be hitting a metal pipe instead of a rubber one...
Jdav79's Avatar
The DV Flutter is going to depend on the amount of boost you are running. Or maybe you just got one that sucks and does not want to stay shut.
Typically they will hold boost to about 20/21 psi or so, but they do leak much sooner in most cases.
Upgrade to a Forge DV or the FORGE RS.
Old Apr 19, 2007 | 07:41 AM
BURNALL_4's Avatar
Its hooked up backwords.....The stock DV hardly need any pressure to open. It's not the DV making that noise its compressor surge that sounds like that.
Old Apr 19, 2007 | 07:48 AM
Jrod@Buschur's Avatar
Yes the sound being louder is normal. The Evo 9 valve should not flutter. We run this on our BR350 Evo 9's without any issue. The Forge valves we were using with the BR350 Evo 9 were fluttering and the oem valve did not have that problem. I am not sure why it should be fluttering. We normally run around 21psi on those cars but have had people run 24ish without an issue. Id check to make sure it was put back in correctly if you took it out.
Glad you are happy with your purchase and the service you recieved from us.
Old Apr 19, 2007 | 07:49 AM
yikez's Avatar
spiking 23psi and holding 19/20 till redline. stock plastic DV
Does anyone have any pics of how it is supposed to look liked hooked up (the DV) i want to maje sure mine isn't backwards.
Old Apr 19, 2007 | 07:50 AM
Jdav79's Avatar
I thought the IX's came with the new Metal DV?
Old Apr 19, 2007 | 07:52 AM
yikez's Avatar
I was surprised mine was the plastic DV, i thought european evo ix's had the jdm dv
does anyone have any pics of the DV valve installed so i can see if mine is on backwards?
Old Apr 19, 2007 | 05:37 PM
Spikedlee's Avatar
correct diveter position
A lot of people never realize this, but on the stock DV there is a little arrow symbol on the side of the opening end that should be facing down. I noticed on my old 8 DV that there was some white paint in the same area designating that point. Look for this arrow as shown in my picture comparison. I hope this helps.
Attached Thumbnails Stock DV and Buschur Intake-diverter.jpg   Stock DV and Buschur Intake-engine-bay.jpg
Old Apr 19, 2007 | 05:44 PM
evolrobert's Avatar
my flutters alot too, why?
Old Apr 19, 2007 | 05:46 PM
jcdevo67's Avatar
They are gunna be alot louder after an intake. Ive had a ssqv and the stock is almost as loud as it.
Old Apr 19, 2007 | 05:56 PM
Spikedlee's Avatar
If it is a very noticable fluttering and you feel a jerking feeling when it does, most likely you have it on backwards as I did when I first had my car. It should be a smooth almost whiplash sound upon release. However, if you are in a high gear like 5th and driving at a low RPM and then release the gas after pushing on it a bit for boost, you might hear a bit of a flutter.
Old Apr 19, 2007 | 06:05 PM
tripperfx3's Avatar
That fluttering should only happen in low boost/cruising applications. You need to get that checked out and if your IX came with a plastic DV then you need to swap it for a metal one. Did you buy the IX used?
Old Apr 19, 2007 | 06:16 PM
gsrboi80's Avatar
The side port goes to the intake and the botom port goes to the UICP. As stated a low boost on and off the gas situation could result in a slight flutter with the Metal DV.
It should not allway flutter or buck when letting off the gas or shifting this would be an indication that it was installed backwards
Old Apr 20, 2007 | 08:52 AM
MRQ06's Avatar
If you have the IX you should have the metal DV or BOV. and regarding the fluttering in low RPMs im pretty sure its a compressor surge.
http://72.14.253.104/search?q=cache:...nk&cd=7&gl=us:)
