Adjust trunk alignment...
Old Apr 30, 2007 | 12:45 PM
amstel78's Avatar
Question: just noticed the other day that the right rear corner of my trunk (closest to the rear wiper and glass) does not line up flush with the rear quarter panel. On the contrary, the left side lines up fine. I don't have a picture to show, but when looking at it, the right corner seems to be pushed down a little... it seems it's about 1.5-2mm lower than the ridge line of the quarter panel. Because of this, when you open the trunk, that corner rubs slightly against the rear windshield corner and side molding. I don't know if it was bent like that from the factory, or if this is something I can adjust by shimming the trunk mounts? Suggestions? Perhaps just let the dealer worry about it?
P.S. Car is new, no accidents.. so I'm guessing shoddy work from the factory, or they slapped on a trunk with a slightly warped corner.
Old Apr 30, 2007 | 01:23 PM
FiftyFive's Avatar
You can always adjust it by loosening the bolts holding the trunk lid and moving it.
Old Apr 30, 2007 | 01:37 PM
amstel78's Avatar
That would only offer lateral movement.. the right edge corner on my trunk however seems to be lower than the left edge corner, making it out of flush with the right rear quarter panel. I guess I'd have to bend that corner.
Old May 1, 2007 | 08:16 AM
Jer.k's Avatar
Theres 2 rubber height adjuster screws on the inside of the trunk lid you can try..1 on each side
Old May 1, 2007 | 10:35 AM
chrismnj's Avatar
go to the body shop
b0yw0nder
Jun 4, 2016 06:45 PM
ReaperSevero
Jul 9, 2009 09:10 PM
Noize
Mar 24, 2008 03:27 PM
pgmike
17
Feb 20, 2005 10:58 AM
purecoda
May 2, 2003 08:17 PM
