Is anyone else's oil dipstick poping out?
Old May 2, 2007 | 01:06 PM
Kevin Knight's Avatar
Is anyone else's oil dipstick poping out? just got a used evo and the day after i changed the oil the dipstick poped out creating a huge mess. it has so far happened to me 3 times and i finnaly have had enough. i ordeed the B.R. dip stick spring and for right no i have a zip tie around it. ive heard that your comprssion is to high and you have blow by. was thinking of having my comppresion checked but i dont know why the dip stick only poped out after i changed the oil?
(and yes i know i just had a tread like this but i need a good anwser)
Old May 2, 2007 | 01:08 PM
Cloud's Avatar
Maybe when they changed your oil, they didn't plug it in all the way?
Old May 2, 2007 | 01:17 PM
amstel78's Avatar
Sounds like the effect of blow-by, but that would only happen if your head gasket is going bad, or you have cracked cylinder liners. What's the color of your oil on your oil cap? If it's a milkish brown, that's a bad sign. Check your coolant level also.. if it's rising and you're not putting anything in.. that's another sign.
Old May 2, 2007 | 01:57 PM
binh's Avatar
buschur has a solution. PM him
Old May 2, 2007 | 02:01 PM
jmartinez1170's Avatar
yep all the time this is a common problem. I just use a ziptie to hold it down
Old May 2, 2007 | 02:04 PM
mac_05evo's Avatar
Old May 2, 2007 | 02:08 PM
cdupont03's Avatar
I still dont see hope people can say this is not a problem, your dipstick popping out is one thing. I had that happening replaced the o-ring and crimped the tube the tiniest bit. But when oil is physically being forced up the dip stick from the oil pan and shooting out how is that not a problem. someone please explain this to me.
Old May 2, 2007 | 02:16 PM
Cloud's Avatar
How is this a common problem?
I know a lot of people with Evos and working at a shop tons of them have come by. None of them have dipsticks just shooting off.
I was being serious when I asked if you plugged it in all the way. Has the only time it happened after you changed your oil?
Evos don't normally blow by. It's not a Subie.
Old May 2, 2007 | 02:32 PM
05blue8's Avatar
It IS a 4G63, essentially...
DSM's have been haunted with this issue since their creation in 1989. It's very very common for them and this isn't the first thread on the "dipstick" popping out issue. I had 0 problems with my DSM but the dipstick popped out. My fix was just crimping the top of the tube a bit. This is just like the Brembo brake issue, some guys have the peeling and cracking, and some don't, some have a popping dipstick, some don't. One of the most famous DSM'ers (Buschur) out there has a "fix" and his fix does not involve going into detail about any "problems" with the car, it's just something that happens on some Evo's.
Old May 2, 2007 | 02:50 PM
pog0's Avatar
I have never had an issue with my dipstick. 36k miles. I did zip tie it down when I went to the track on Saturday.
Old May 2, 2007 | 03:36 PM
94AWDcoupe's Avatar
a poor sealing pvc valve can cause this as well. it would be like a boost leak direct into crankcase.
Old May 2, 2007 | 03:43 PM
Murf's Avatar
My friends dsm did this...to much pressure build up...check you pcv valve..his was not working right...swapped it out and no more problem.
Old May 2, 2007 | 04:28 PM
eddie's Avatar
Lot of track ****** have this problem. No biggy. Zipties are your friend...
Old May 2, 2007 | 05:23 PM
sonicnofadz's Avatar
44k, 24 psi, no popping dipstick. Check your compression, you probably are getting alot of blow by. Also try replacing your PCV valve.
Old May 2, 2007 | 06:33 PM
cdupont03's Avatar
Ok yes buschur has the fix for a dip stick popping out all the time but I dont think thats the same problem as oil shooting out of the dip stick hole. that would mean theres an excess of pressure and I just dont see how just sealing it would fix anything as there would still be an excess of pressure build up which just doesnt have anywhere to go now. I have had both problems and if your shooting out oil when hitting high boost check your PCV if its all the time though could be something else.
