You guys with lowered Evos
Old May 8, 2007 | 09:10 AM
anjapower's Avatar
How the heck do you guys jack up your cars?
I scrape the stock lip a bit if I use Rhino ramps and my floor jack won't clear the front lip even when I drive up on two 2x4s stacked on top of each other.
What is the easiest and most cost effective solution? My car isn't even that low
Old May 8, 2007 | 09:12 AM
akemi27's Avatar
there was some rhino ramps on sale here a while back where the height was more accomodating for lowered cars...i usually get my oem jack, then use my hydraulic after i get it up a bit...don't use ramps for this reason...
Old May 8, 2007 | 09:16 AM
anjapower's Avatar
yeah I remember those...they're 200-250 dollars. Total rip off for ramps.
I suppose I could use my factory scissor jack to get it high enough to use the floor jack...not a bad idea but sort of a PITA.
Is this what everyone usually does? I can't believe how low the lip gets with even moderate ride height reduction.
Old May 8, 2007 | 09:20 AM
t51splbb's Avatar
I typically use a lift to raise the car but if I have to use a jack, I lift the car from the sides using a low profile Sears aluminum jack,they typically go for $175 on sale.
Old May 8, 2007 | 09:22 AM
YzBrad99's Avatar
i just use a 2 post lift, its easy because the pads are 2 inches off the ground. plus i can stand under the car.
Old May 8, 2007 | 09:39 AM
jimsevo8's Avatar
I usually use the low profile jack from the side like t51splbb. I place the pad of the jack under the body seam where the factory scissor jack would go if you were using that.
If I am doing something that requires all 4 wheels off the ground, I do the rear first and jack it up from the middle, put jackstands under the rear control arm pivots, and then go to the front and do that one side at a time.
Old May 8, 2007 | 09:44 AM
4WS Tuning's Avatar
my floor jack is from bennett auto it fits under my car with tanabe springs
its the yellow jack, the red one is too big
$30-$35 dont remember
Cheers
Old May 8, 2007 | 09:54 AM
Warrtalon's Avatar
I jack from the sides with my red, aluminum Craftsman floor jack - from Sears, of course. It barely fits under the sideskirts, and if I jack up one side, I have to make sure I don't go too high, because then I can't get under the other side.
Old May 8, 2007 | 10:14 AM
8thWonder's Avatar
I jack up the sides or from the front with my aluminum floor jack. I'm on Hotchkis springs and it's never been a problem.
Old May 8, 2007 | 10:18 AM
EvoInvidia's Avatar
i just use 4 jackstands and use a jack to lift the car. that way all 4 wheels are off the ground so i dont have to jack it up after im done with one side.
Old May 8, 2007 | 10:58 AM
Mad_SB's Avatar
raceramps or a low profile race jack. I picked up a $75 "race" jack from autozone that works fine for my evo, but I'm only lowered about 3/4"
Old May 8, 2007 | 11:48 AM
anjapower's Avatar
The ~120 dollar one or the ~200 one? I've heard from many people that those things are pretty flimsy and break after a few uses. How has yours held up?
Old May 8, 2007 | 12:07 PM
sonicnofadz's Avatar
I use my $80 harbor freight aluminum racing jack. It can go as low as three inches:
Old May 8, 2007 | 12:08 PM
RalliArtEvoVIII's Avatar
my god what are u sitting on? i've had S techs on my previous evo and Hotchkis on my current evo and i could use my $25 autozone floor jack no problem
Old May 8, 2007 | 12:10 PM
hondafan's Avatar
i have a decent aluminum jack from jegs.com. pretty good price, it's under their garage equipment section. i was gonna get the craftsman but have heard alot of bad reviews about them so i went with the jegs, had it for about a year, no problems. nice and light too. the craftsman still is pretty heavy cause it's still mostly steel, the jegs is mostly aluminum.
