How do I stop the car from blowing the horn when I lock the doors?
Old Jun 15, 2003 | 11:08 PM
caymandiver75's Avatar
Question How do I stop the car from blowing the horn when I lock the doors?
Anyone know how to disable the car from blowing the horn everytime I lock the doors with the remote? I really really hate that and wish it would just chirp or make no noise when I lock the doors.
Old Jun 15, 2003 | 11:35 PM
rklancer's Avatar
yeah i recently read somewhere, may have been th eowners manual, that you o the following:
hold the lock button down for 2-3 secs. that disables the horn feature when u lock the car. then give it a second or two and try again to see if that worked. i belive it is just holding the lock button down for a certain period of time to disable the feature, and to re-enable it, you would just hold the button down for the smae length of time again.
that should work.
Old Jun 15, 2003 | 11:44 PM
awesome news I will try that first thing tomorrow. If this works I owe ya one
Old Jun 16, 2003 | 05:54 AM
neilschelly's Avatar
If that doesn't work, then just read the car manual. The remote has a couple different modes depending on the combination and duration of holding buttons and it's all specified in there.
-N
Old Jun 16, 2003 | 07:51 AM
Lightsped's Avatar
Sit inside your car to do this so you can hear the beeps. It may take a couple tries to get it right.
Hold the Lock button down for 6 seconds. While holding the Lock button down, push the Unlock button for 3 seconds. Release both Lock and Unlock button at the same time. You will hear 2 beeps. Do the same process for the 3 beep settings.
Check your owners manual for description of 1 beep, 2 beep, and 3 beep settings. They are all different setups.
Old Jun 16, 2003 | 08:14 AM
Thanks guys my horn no longer blows when I lock the car.
Old Jun 16, 2003 | 09:03 AM
I got the horn to not blow when i lock the car, but what is the 3 beep settings thing you mentioned?
Old Jun 16, 2003 | 09:18 AM
nastea's Avatar
i wonder how long it took you to get the answer online, when you could have looked at i believe page 3-7 in the manual.
You might try reading up on the car....the manual explains things.
Old Jun 16, 2003 | 09:30 AM
yeah i know.... but as a typical guy we always hate reading manuals and try figuring things out ourselves. I did take a look at the manual after I realized this was discussed there. I honestly didn't expect something like that would be there but I was wrong.
Old Jun 16, 2003 | 09:44 AM
nastea's Avatar
if its stock it would be there
Old Jun 17, 2003 | 08:05 PM
soapsuds's Avatar
Along with the instructions on adjusting our non-adjustable USDM rear wing?
Old Jun 18, 2003 | 02:50 PM
Overload's Avatar
autolocking?
Can the evo auto lock the doors at 5mph or something like that? I thought I read about it a long time ago, but I may be thinking of when I was following the MINI.
thanks,
Old Sep 12, 2003 | 06:39 PM
90GSX-03EVO's Avatar
The non-adjustable wing is not a USDM thing. The Non-adjustable part is an Evo 8 thing. That portion of the manual comes from the European Evo 7 manual FWIW.
josh
Old Sep 12, 2003 | 11:24 PM
Chris in HB's Avatar
You can adjust the wing with a hacksaw and crazy glue. Set the angle of attack however you want. It's right there in the manual...
Old Sep 13, 2003 | 09:11 AM
I used duct tape and JB Weld. I couldn't locate any crazy glue and I really needed that extra downforce.
Josh
Ernest Latcher
Jan 4, 2017 06:31 AM
Ernest Latcher
Jan 3, 2017 09:40 PM
IXmr321
Mar 26, 2008 05:27 PM
Nosaj$$MR
Aug 24, 2006 08:32 PM
mazdryk
Mar 27, 2006 07:18 AM
