Damn stock cat bolts!
Old May 23, 2007 | 04:46 AM
BaLListic_EVO's Avatar
sounds like maybe you need to put some more umph into it lol... i ended up twisting one of mine off bolt broke in two..... but the rest came out fine.....
Old May 23, 2007 | 05:14 AM
rcheung's Avatar
Originally Posted by 03SilvaEvo
Oh forgot to tell ya I used lots of PB blast, wd40 and seafoam deep creep. Applied it a day before I went to tackle it. Did the heating technique with the torch too and no success . SInce the nuts are stripped a bit is there a socket that can remove stripped nuts?
Yes there is.
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Old May 23, 2007 | 06:02 AM
PorkRoll's Avatar
PB Blaster then heat the **** out of the bolts, then use a breaker bar. If you break the bolt, just go buy a new one. Good luck.
Old May 23, 2007 | 05:57 PM
03SilvaEvo's Avatar
Got the passenger side nut off finally! BUt driver side still don't wanna budge. I got one of them nut removers for stripped nuts. I rented an impact gun and that didn't work out too well. Anyway, as I was trying to loosen the nut on the driver side with the breaker bar and nut remover I friggin kinked the mid pipe just behind the flange . Don't ask me how. Not that bad though and I hope it won't affect exhaust flow that much(now I just added more back pressure ). Any way to fix a kinked exhaust? Man this is turning out to be fun and aggravating at the same time
Old May 23, 2007 | 06:02 PM
sl0ev0's Avatar
3 days and still no success! whoa! what helped me was to keep the exhaust from moving. have someone else hold it in place. i think it absorbs alot of the torque when its moving. im wimpy and me and my wimpy friend got mine off without being on a lift
Old May 23, 2007 | 07:30 PM
03SilvaEvo's Avatar
Since I don't have a garage to work in, the only place I get to work on the car is on the driveway when the weather is nice. Garage is filled with gym equipment and tools so no room. And everytime I do work on the car and don't succeed at completing a job(such as this) I'll get away from it(just because I'm too frustrated) and come back to it the next day weather permitting of course. Wish I had a 2 post lift on my driveway...that would be awesome!
