Damn stock cat bolts!
Old May 20, 2007 | 07:14 PM
03SilvaEvo's Avatar
I did get the downpipe to cat bolts out though! just those other two are just welded on there(at least thats how it feels to me). I got a cutting wheel and attached it to my corded drill, tried to cut it and it takes forever. I might have to get a grinder instead. Anyone ever use one to get bolts/nuts off? What grinder do you suggest I get. I know a lot of you will say to just go to a muffler shop but I'm so pissed at these rusted nuts that I'm determined to get them off.
Old May 20, 2007 | 07:16 PM
moreryce's Avatar
i just used alot of penetrating oil and wd40 and they came off with the right tools.. ex) 1/2 breaker bar..
Old May 20, 2007 | 07:18 PM
Blue By You Evo's Avatar
yeah the breaker bar works wonders but u need to get the car up high enough so u can have room underneath to break them
Old May 20, 2007 | 07:54 PM
03SilvaEvo's Avatar
I should have done that(wasn't thinking). Car was on Rhino ramps. Time to put it on jackstands. As far as the nuts go, I stripped them a little bit already so I'm afraid if I use the breaker bar it will strip it even more
Old May 20, 2007 | 07:56 PM
well let the car cool down, then get a flame and heat the bolts. This makes them expand a little off the threads and may be easier to get off.
Old May 20, 2007 | 08:01 PM
JRB_EVO's Avatar
This recipe works wonders, I used it Friday night while installing my AMS TBE.
Old May 20, 2007 | 08:21 PM
03SilvaEvo's Avatar
Oh forgot to tell ya I used lots of PB blast, wd40 and seafoam deep creep. Applied it a day before I went to tackle it. Did the heating technique with the torch too and no success . SInce the nuts are stripped a bit is there a socket that can remove stripped nuts?
Old May 20, 2007 | 09:22 PM
ziggity's Avatar
PB blaster and impact gun did it on the 1st try.
Old May 20, 2007 | 09:28 PM
fq340's Avatar
i burned mine til its red.. then got them loose... had my car on a lift so it was easier to do but still... it was just pain in the as...
Old May 21, 2007 | 12:35 AM
IfDontFITsPIT's Avatar
just impact gun mine... it was still a b**ch
Old May 21, 2007 | 01:22 PM
Nosaj$$MR's Avatar
got to love them air tools
Old May 21, 2007 | 02:11 PM
Mitsu3's Avatar
let the car run to warm the exhuast up really hot then try to get it off
Old May 21, 2007 | 02:32 PM
wisocrazy's Avatar
rtfl
just use lots of wd-40... or just try to loosen the bolt itself rather than trying to loosen the nut... it can be a b!t<h, but you'll appreciate your long hard work in the end...
Old May 22, 2007 | 09:02 PM
qwon526's Avatar
having the same issue removing stock rusted bolts but i now have the adapter/extension for the gun so hopefully it should come off fairly easy. Now to think of it theres one bolt on top the gun won't reach, dp to cat .. guess i will try a mallet w/ socket wrench on that one
Old May 22, 2007 | 10:19 PM
Jordanz3's Avatar
sux to hear. good luck to you
