Need Help! What is a p0118 code?
Old Jun 9, 2007 | 10:14 AM
SidewaysEvo's Avatar
I know what it means. But how do I fix it? I changed the thermostat sensor and that did not work. Any one know about how to get rid of this code?
Old Jun 9, 2007 | 11:55 AM
EuroEclipse's Avatar
you replaced the thermostat already, so try replacing the coolant sensor.
Old Jun 9, 2007 | 03:58 PM
I also did that, no luck. The check light is still on.
Old Jun 9, 2007 | 05:22 PM
Dapper Dan's Avatar
did you try erasing the code?
Old Jun 9, 2007 | 05:46 PM
Yea I tried but it comes back right away.
Old Jun 9, 2007 | 07:35 PM
KcEvil8's Avatar
you sure you replaced the right coolant temp. sensor? there should be one for the ECU and there is one for the gauge.
Old Jun 10, 2007 | 01:16 PM
sleet's Avatar
I just had this problem, have you done any wiring lately? I'd check all your connections if anything is tapped into the ECU, that was my problem.
Old Jun 10, 2007 | 01:34 PM
I will double check all I did was wire up my defi gauge.
Old Jun 10, 2007 | 05:38 PM
evo150's Avatar
which defi gauge did you wire up? i would double check your wiring
Old Jun 10, 2007 | 05:52 PM
I just wired up the control unit to the radio harness.
Old Jun 13, 2007 | 09:49 AM
Where is the other plug for the gauge? The only one I replaced was the one plugged into the thermostat housing.
whitevo88
Dec 9, 2011 04:38 PM
chazyronnie
Oct 20, 2010 08:47 PM
billylancer
14
Apr 8, 2008 05:11 PM
bboy_RES
Feb 2, 2008 01:35 PM
evo8fl
Feb 7, 2007 08:39 PM
