beware guys!! "please read"
Old Jun 17, 2007 | 12:44 PM
upstatescevo's Avatar
mine came from the dealership on backwards and it flutterd loud
Old Jun 17, 2007 | 12:45 PM
CT9AEvolution8's Avatar
I don't understand how it could be installed backwards, but I think mine's fine since I've been running it the same way for 66000 miles ~ .^_^.
...and CasperGSR... the answer is "negative." VW guys are so not FTW hahahaha
Old Jun 17, 2007 | 12:46 PM
CasperGSR99's Avatar
yes but is the "flutter" going to damage something? it still holds boost correct?
what are the pro's con's of having it backwards? (and i admit it theres a little rice in me where i'd like to hear it a little louder but not so much that id ever consider a VTA)
Old Jun 17, 2007 | 12:47 PM
hahh theyre still my friends tho CT9A, but with theirs flipped (not really backwards guys its really more flipped) it would still hold boost, just give a little more sound
Old Jun 17, 2007 | 01:04 PM
TunerHead24's Avatar
Ok, I Guess Im Gonna Be The Ginny Pig, Im Gonna Install It On "backwards", I'll Kepp You Guys Posted......
Old Jun 17, 2007 | 01:21 PM
PVD04's Avatar
Installing it backwards puts unnecessary stres on the turbo. This has been discussed several times here on the forums. When you close the throttle the DV allows the pressure in the IC piping to be released. If you install the DV backwards, the DV does not release as quickly and the compressed air in your intercooler piping tries to go backwards through the turbo. With a turbo that could be spinning as fast as 100,000 RPM you probably don't want to have air trying to spin it backwards. It will significantly decrease the life of the turbo.
-Paul
Old Jun 17, 2007 | 01:23 PM
occultworks's Avatar
Dude, it's not a big freakin deal. I installed my forge backwards and have never had problems with it. Only slight flutter at freeway speeds, which is to be expected from any DV.
The reason it's backwards you ask? The stock vacuum line is too short to install it the "right" way.
Old Jun 17, 2007 | 01:29 PM
TRUE-GRIT's Avatar
Hi, I found BOV Installation instructions. Good luck!
NOTE: Cut and paste the link. Click on the picture to enlarge!
http://evomoto.com/tech_info.php?tPa...a07145389101f7
Old Jun 17, 2007 | 01:55 PM
Dapper Dan's Avatar
get a longer line smart guy.....lol
Old Jun 17, 2007 | 01:58 PM
yikez's Avatar
i really doubt it was installed backwards from the factory.
either you bought yours used and the previous owner had it on backwards, or you simply had some minor job in the engine bay that required its removal, and the mechanic put it back on backwards.
It's a good idea to check if people have theirs on backwards as it's easy to install it the wrong way, but i wouldn't start checking if every DV was installed right from factory lol
Old Jun 17, 2007 | 06:09 PM
steevo's Avatar
Originally Posted by bbyevo8u
p.s. the brass looking hat on the bypass valve should NOT be facing up tords the hood it should be sideways! the side vent should be going tords the intake piping and the bottom should be going tords the intercooler piping!
John
If your Evo was stock, you DV would not be brass. It would be plastic since you have an 8. So, whoever upgraded your DV messed up, not mitsu. Not saying it doesn't happen though.
Old Jun 17, 2007 | 09:13 PM
lemmonhead's Avatar
cars come stock with the negative and postive battery terminals switched, and it still runs without them knowing, go figure.
Old Jun 18, 2007 | 01:12 PM
people tell me its good putting it on backwards and people are telling me its bad putting it on backwards, who is f-ing right???
Old Jun 18, 2007 | 01:50 PM
DSM GSR04's Avatar
Its Bad!
Old Jun 18, 2007 | 03:22 PM
sna08's Avatar
im sure it's bad... paul seems to make a good point
