Weird Cricket noise coming from engine by belts - PLEASE HELP!!
Old Jun 21, 2007 | 01:46 PM
threefiftyse7en's Avatar
Question Weird Cricket noise coming from engine by belts - PLEASE HELP!!
Hey guys, hopefully someone here might be able to give me an idea of what this noise may be or what to look at. The only way I know how to describe it is it sounds like crickets chirping down by the alternator and the belts. It is NOT coming from the inside the engine itself, I know for sure it is coming from the belt area / alternator.
I do realize it will be nearly impossible to diagnose without actually hearing for yourself, but if you could just give me an idea of what it may be because it is annoying as all hell. Thank you in advance for any suggestions and help.
Will
Old Jun 21, 2007 | 01:50 PM
Will
My bad I double posted this one. Mods please delete. Thank you
Will
Old Jun 21, 2007 | 02:16 PM
4g63tFan@tic's Avatar
The chirping sound happens when the belt is too loose and/or glazed on the friction side due to wear. When this happens the belt slips on the pulleys causing the noise. Think of a sneaker on a hardwood floor, when it slips, it chirps. You should just throw on new drive belts and problem solved. I have not changed the belts on my evo yet, but there may be a adjustment. If it has an adjustable tensioner rather than a spring loaded tensioner, you can just tighten the belt by adjusting the tensioner, but if it is spring loaded you cannot and just have to swap belts. Hope this helps.
Old Jun 21, 2007 | 02:20 PM
smokedmustang's Avatar
..........................Did you look for Crickets? Sounds like a belt to me also.
Old Jun 21, 2007 | 02:22 PM
Speed Corps's Avatar
Former Vendor
Get some belt dressing and spay it on. Make sure you only get it on the belt. If it continues, then it's probably a pully making some noise. I believe they have a silicone spray to fix that.
Old Jun 21, 2007 | 02:24 PM
LOL, of course I looked for the bugs. jk
Seriously though, thank you guys. That noise was annoying as hell and now I can go replace the belt.
Old Jun 21, 2007 | 02:30 PM
I would not advise using belt dressings. They will dry rot your belts, which will eventually lead to failure. Just buy some new belts and fix it right.
Old Jun 21, 2007 | 02:40 PM
Kdash106's Avatar
i have the same problem for over 3000 miles, and i am determined is the idler pulley. its at the lower part of the belt area right?
Old Jun 21, 2007 | 02:44 PM
sharkm87's Avatar
I have the exact same issue iwht mine oto, if you hit the gas lightly and release, you can really hear it than while idleing...i know exactly the sound you talking about and when i describe it to people i also call it a criquet sound....how much do belts normally cost?
Old Jun 21, 2007 | 02:51 PM
Kdash106's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=262773
this should help
and this https://www.evolutionm.net/forums/sh...d.php?t=256666
Old Jun 21, 2007 | 03:55 PM
Thank you again for all the replies. I am 99.9% sure I now know what it is. I have determined it is the belts and I am just gonna take it to the dealer and have them replace it since the car is damn near new and still under warranty.
it also seems like it is a fairly common noise for the Evo IX. Just happy to know it is not anything major and will be an easy fix.
Sharkm87: I have the same problem, hit the gas and you really notice it. I'm just glad to know other people have had this issue already and it is not anything in the motor itself and just a simple fix like replacing a timing or idler pulley.
Old Jun 21, 2007 | 06:29 PM
sharkm87's Avatar
it actually may be the timing...when i brung my car in for service they changed the idler pully and i still notice the noise, i haven't gone back yet
Old Jun 21, 2007 | 06:46 PM
Kdash106's Avatar
when u guys listen to it, it's at the very bottom of the belt area right? cause someone did change their idler pulley and got it fixed. i thought it was the belt too, but won't the belt make the whole area make the same noise?
Old Jun 21, 2007 | 06:52 PM
GPTourer's Avatar
I had this problem in both my cars, both crank pulleys but for different reasons.
You need to get this checked out and fixed ASAP.
JordanG
Jan 13, 2016 05:12 PM
manofhonor
Dec 10, 2008 02:04 AM
KBkilla0006
Lancer Troubleshooting
35
Apr 7, 2008 10:14 PM
Lunchb0x
Mar 25, 2006 09:56 AM
