Engine Ticking, Not Lifters
Old Jul 8, 2007 | 10:08 AM
  #31
Evology's Avatar
well.. the thing that got me worried is that a friend of mine (a mechanic) got a car with what he describes on the phone, a tick with the attributes as mine. and it turned out to be a damaged piston (ring land) .. the tick was the piston slapping the block!
Old Jul 9, 2007 | 08:42 AM
  #32
Evology's Avatar
took it to the dealer, lets see what they have to say about it!
Old Jul 9, 2007 | 08:52 AM
  #33
TSiAWD666's Avatar
Exhaust leaks from loose connections or cracks can result in ticking noises as you'll hear the valvetrain, and these will change in frequency along with RPM.
Old Jul 9, 2007 | 09:35 AM
  #34
Smokin Evo's Avatar
Your car runs????? I wish mine did that!!! Hasn't moved in a year. Can you say Building a monster!!!!!
Old Jul 9, 2007 | 01:17 PM
  #35
Evology's Avatar
thats a very good point there, ill check out the manifold and downpipe, since it was glowing red when when i was drifting.
Old Jul 10, 2007 | 02:26 PM
  #36
GBEvo's Avatar
Any news from the dealership yet?
Old Jul 11, 2007 | 06:08 AM
  #37
Evology's Avatar
not yet, but.. ive already put aside some money for a stroker kit.. if all comes to worst that is
Old Jul 11, 2007 | 06:17 AM
  #38
subrwho's Avatar
I have a tick too. . . Hopefully its just a lifter
You have me worried now! lol
Old Jul 11, 2007 | 06:32 AM
  #39
Sharkbite2000's Avatar
I had a super tick which I have the video, Pruven Performance installed my head and told me it was normal, found out from AMS that I had bent valves.
Old Jul 12, 2007 | 07:11 AM
  #40
Evology's Avatar
and bent valves will show on a compression gauge right?? seeing how the valves wont seal properly.
Old Jul 12, 2007 | 11:19 AM
  #41
ajbreezay's Avatar
mines 2!!
-Aubrey
Old Jul 12, 2007 | 11:36 AM
  #42
BlackOps's Avatar
Mine ticks as well. It does go away when I push in the clutch, comes back when I let the clutch out. Only seems to happen at idle, or maybe I can't hear it over road and motor noise while driving. Its pretty loud. I had a friend tell me he would guess it was the throw out bearing going out.
I personally think its the AC, cause it also shuts off when I turn off the AC, or maybe that just causes enough vibration to bring it out to a noticeable level, not sure.
Old Jul 12, 2007 | 06:58 PM
  #43
SwabeLife's Avatar
Originally Posted by mdsevo06
As sugested, get a scope and try to narrow it down to a specific area. The Timing Belt area will make noises as well, Tensioner, Idler or Belt it self.
The only noise I get around the Valve Train, are typical Lifter and Injectors, which are normal. You should hear Injectors on a Ford.
I got this noise as well after putting cams, gears and new belt. the belt makes a humming noise, they said it's to tight and hopefully it goes away after losening the belt.
could the tight timing belt could cause the ticking noise too?
OP, sorry to jack up your thread.
Old Jul 13, 2007 | 08:52 AM
  #44
Evology's Avatar
well.. it didnt happen after any new installs.. just after some heavy load and aggressive driving.
the timing belt humming is normal.. just loosen it up a bit, and give it some slack, not too much.. but just enough! or the belt might snap! happened on my RB25!
Old Jul 15, 2007 | 10:46 AM
  #45
onesexyevo's Avatar
I brought my car to the dealership for the ticking problem it acuatlleysounded like a rattling but when i pushed the clutch in it went away.Ithought it was the throw out bearing but they told me it was the fans they are loud on the evos..
