Clutch/Trans Problem...
Old Jul 14, 2007 | 08:49 AM
Dont Try To Run's Avatar
Hey Guys,
Whenever I downshift from any gear to one lower, the instant the clutch catches (I am slowely letting it catch, not dumping it), i hear a weird noise sorta like a groan... I don't know how to explain the noise but obviously this can not be a good noice. Any insights on if this is a clutch or trans? I am pushing 497awhp on a Exedy Twin Disc Clutch with a stock drivetrain... I need to send my transfercase and Transmission to Sheppard soon... Is this the time?
TJ
Old Jul 14, 2007 | 08:57 AM
Thegame's Avatar
I don't think it's any big problem. It's the release bearing that you're hearing. Although the stock throw out bearings are prone to this noise, I assume some aftermarket ones are as well. Nothing to worry about as long you're not grinding or slipping or anything.
Old Jul 15, 2007 | 09:28 PM
Ok thank you. That is what a few buddies told me who have Evos and I decided to post it on here. They mentioned it could be the stock pressure plate as well. Thanks though
Old Jul 15, 2007 | 09:54 PM
IEXCELR8's Avatar
Could be TC groan. Did this just start to happen? Is it more of a vibration, if you leave a bit of pressure on the clutch does it go away? More of a rattle noise?
Old Jul 15, 2007 | 10:09 PM
I just bought the car... It seems fairly new, though. It sounds like its coming from the engine bay, not the transfer case in the rear... although i may be very wrong.
Old Jul 16, 2007 | 06:22 AM
EVOgirlie8's Avatar
I have also been told that noises like this may be from the stock pressure plate.... i to have the Excedy twin.. and although i am not making the HP you are.. at times my downshifting results in odd noises as well...
but should the problem be your T-Case.. i have my stock one for sale =)
Old Jul 16, 2007 | 06:29 AM
I dropped you a PM EvoGirlie =)
Thank you all
