main subframe/cross member
Old Jul 14, 2007 | 09:35 AM
19psi's Avatar
How do you remove the main cross member?
how many bolts and what bolts are required to remove the cross member?
It's the member that holds the steering rack.
Thanks in advance.
Old Jul 14, 2007 | 09:44 AM
MrMejia's Avatar
It is a bi*ch to take out. You will have to remove the rear mount as well as the transfer case and passenger drive axle. After you do all that you will have to unbolt the front sway bar and then the steering rack. Then once you do all that you can then go ahead and start removing the crossmember.
Old Jul 14, 2007 | 09:46 AM
MrMejia's Avatar
the only time I took this out is when I did my clutch job to make things easier in installing the tranny. Becuase with that crossmember in it is a PAIN IN THE A** to get that tranny in.
Old Jul 14, 2007 | 09:48 AM
19psi's Avatar
ok thanks.
That sounds like a whole lot of work.
What if I just want to loosen the cross member not completely remove it...what needs to be done?
Old Jul 14, 2007 | 09:55 AM
MrMejia's Avatar
well if you can find a way around the steering column and rear mount let me know because I know of no other way. happy hunting.
Old Jul 14, 2007 | 11:19 AM
19psi's Avatar
Thanks.
I'll def let you know if I find a way
Pal215
Oct 29, 2015 04:32 PM
lostsoulsevo
Apr 15, 2015 05:54 PM
asu11
11
Oct 27, 2014 05:24 PM
daisaw1219
46
Sep 4, 2008 11:13 AM
