ABOUT : Rexpeed Trunk Spoiler
Hi all. I will remove my evo IX spoiler and then i will take Rexpeed Type-C Carbon Fiber Trunk Spoiler. But i am worry about the aerodynami.
if i do this replacement does it make negative aerodynami?
Thanks.
Thanks.
It will provide less downforce than the stock wing, but unless you're going over 120 mph, it should not be very noticeable. There are things you could do to offset the loss of rear downforce, such as getting a rear undertray and/or installing a vortex generator.
l8r)
l8r)
It will give you some downforce, but not as much as the stock wing. If you don't track your car that much or tend to drive 100mph daily, then I wouldn't worry about it. The only negative thing I can think of is less downforce than the stock wing.
Then I'd get a rear undertray to go with it. Should make the car feel more planted at speed, since, among other things, it eliminates the parachute effect of the rear bumper. You gas mileage at that speed should go up too.
l8r)
l8r)
which undertray do you suggest ?
