throttle body question
Old Jul 27, 2007 | 06:33 PM
wsb840's Avatar
so i just did a boost leak testand found a leak at the tb. Did some looking around and it sounds like its my tb shaft seals. So my question is which seals to use (holds boost best 22psi) Works, Mach V, or Napa? If the ones from napa work id rather get those cause its a local pick up. thanks
Old Jul 27, 2007 | 07:12 PM
Kerr's Avatar
Fomer Vendor
I don't think it matters which you go with. I got the ones from Mach V.
But an install tip for you, when your installing the new seals, put the TB shaft in backwards. Lube the seal up with the dielectric grease and slide it over the shaft, use a 10mm socket to tap it into place. Pull the shaft out and install it the correct way, then install the 2nd seal. This will keep the seals lined up and they will go in easier.
Old Jul 27, 2007 | 07:18 PM
gsrboi80's Avatar
I have to do mine too. I just havent got to it yet
timmycat
Mar 23, 2015 02:04 AM
rartist
16
Sep 6, 2010 12:33 PM
freakitgood
Mar 19, 2009 12:13 AM
Turbo Kyle
Aug 18, 2008 08:07 AM
MrSpeedDemon
Sep 12, 2006 10:11 AM
