Hks Dli Ii
Old Jul 28, 2007 | 07:49 AM
Olynth's Avatar
Hks Dli Ii
We installed DLI II 2 days ago and there is a problem with it.
i tested it on the highway and at full throtle it cuts something. but not every full throtle. when the peak comes it makes this. car cuts itself and didnt go.
i gived it to the dealer and tried another dli and the same things.
what can it be ?
Thanks.
Old Jul 28, 2007 | 02:07 PM
Olynth's Avatar
bumpppp
Old Jul 28, 2007 | 02:24 PM
Roberto's Avatar
Most likely the install is not grounded well enough.
Old Jul 31, 2007 | 03:18 AM
Olynth's Avatar
anybody have a dli 2 installed pic ?
Old Jul 31, 2007 | 04:15 PM
Olynth's Avatar
bump bumppp.
i need help for true installation.
picssss
Old Jul 31, 2007 | 04:22 PM
JordanS4's Avatar
Let me go snap some pics for you real quick.
Old Jul 31, 2007 | 04:43 PM
JordanS4's Avatar
I had to open up the DLI mounting hole a bit for it to fit on the 12mm bolt. The unit is mounted to a factory grounding point right under the Blue H where the AC lines run. It's one 10mm bolt I believe and other wires are grounded to it.
Hooking up to the coilpacks is easy, it only fits one way.
Old Aug 1, 2007 | 02:40 PM
Olynth's Avatar
i will try it again like that.
Thanks alot
Old Aug 8, 2007 | 01:21 AM
Olynth's Avatar
i installed it again like yours JordanS4. and changed my battery. it's better now. but sometimes(full throttle at 3000rpm @ 6th gear when the peak comes) it cuts a little. but i think its not a big problem.
Old Aug 9, 2007 | 03:25 PM
Olynth's Avatar
I have ECUTEK. I didnt remapped after DLI. can it be the problem ?
