alignment and steering wheel position
Old Aug 9, 2007 | 10:55 AM
Fujilicious's Avatar
I couldn't find what I was looking for via a search so this question: In the case of the Evo, is steering wheel position directly related to alignment? My wheel is off but the car doesn't seem to pull on way of the other.
Old Aug 9, 2007 | 10:58 AM
Mr. Evo IX's Avatar
it's your toe settings that control the steering wheel. it will probably eat your tires fast if it's not fixed.
Old Aug 9, 2007 | 11:17 AM
Crap... It's not terribly off; what I've been telling myself is that the right spoke is positioned slightly higher when driving straight to offset for the crown of most roads. Sounds like that might not be the case...
Old Aug 9, 2007 | 11:27 AM
Falcon350z's Avatar
Unless its REALLY off, you should be fine... but if it annoys you, find a good alignment place and have them take care of it. They'll probably either put it back to spec, or put it where you want it... if you're lowered or running coilovers, you might want to make sure they set everything up the way you want it.
If you're not sure what toe is, check this quick resource out: http://www.ozebiz.com.au/racetech/theory/align.html
Old Aug 9, 2007 | 03:53 PM
JDMCT9MR's Avatar
My steering wheel was way off when I got it new!What the hell?I got it fixed at a local suspension shop and the car drives better than before!
Old Aug 9, 2007 | 03:57 PM
cfdfireman1's Avatar
Wrong...
..as long as the total toe is within specs steering wheel position doesn't make a bit of difference, unless it's way way off and then the car will turn one direction tighter than the other.
Old Aug 9, 2007 | 04:02 PM
DSMEVOLUTION's Avatar
Please do not state false information.
Let's say your front left toe is -.05 and right is .05. Your steering wheel will be off a tad but it won't eat your ties because the cross toe is "0". The closer you get the toe to zero and closer the cross toe gets to zero the more straight your steering wheel will be. However your rear toe can also play a factor in the adjustment. A good alignment shop will take care of that within minutes.
Evilami
32
Jan 6, 2014 07:45 PM
zasboy
Aug 11, 2013 07:05 AM
Hiboost
22
Sep 29, 2010 03:18 PM
Shadowpriest
14
Mar 26, 2009 11:09 AM
dek0026
May 15, 2008 03:31 AM
