evo IX VS flash flooding and monsoon storms
Old Aug 1, 2007 | 10:20 AM
4wheel_motion's Avatar
lol,
BluEVOIX's Avatar
Did you change the ACD mode to gravel?
Old Aug 1, 2007 | 10:25 AM
Wolf28's Avatar
Sounds like an interesting time. That stuff can be pretty dangerous though.
You AZ guys should post on AZAWD.org. That is where we usually organize all the meets and stuff.
Old Aug 1, 2007 | 10:37 AM
High_PSI's Avatar
This is a great way to cure heat soak. I did this in my 03. I live on a piece of land that streaches out into the Bay and the acces road floods 2-4 Feet. I plowed through it and had to go fast cuz the exhaust is underwater at that point. Drove well, then my A/C compressor died and shtuff got oxidized by the salt water.
Motor was perfectly fine.
Old Aug 1, 2007 | 10:44 AM
God Given's Avatar
The best thing to do is go so fast that you actually hydroplane across the water. You'll glide across it and hopefully you can save the car from hitting any other cars/people and you be fine no water in the engine or anywhere you need to worry about! Simple enough..
Old Aug 1, 2007 | 10:49 AM
turbochrgdbeast's Avatar
your Evo was thinking..."finally...some real challenge...this gonn be easy!" ...ix ftw
Old Aug 1, 2007 | 11:08 AM
Dinothegreat's Avatar
Originally Posted by 4wheel_motion
lol,
I wish I had a full video for you guys...
Old Aug 1, 2007 | 11:11 AM
VtexGt3's Avatar
i actually blew my front plates off the car doing that once haha now the car looks better!
Old Aug 1, 2007 | 11:50 AM
erioshi's Avatar
Originally Posted by sblvro
change all fluids!
+1
You don't need to worry about the coolant, clutch line or brakes, but I would change the fluid in the rear diff, transfer case, tranny, etc. In my 8 the front diff picks up fluid from the transfer case - not sure if your 9 is the same.
I would also make sure to spot check the all the CV boots to make sure none of them are letting watery grease out. The CV boots should have kept out all the watter, but they are designed for wet weather, not submersion.
Old Aug 1, 2007 | 11:52 AM
sonicnofadz's Avatar
Glad to see she pulled through without hydro-locking! 4G63 FTW
Old Aug 1, 2007 | 12:05 PM
sblvro's Avatar
actually it is better if you drive slow but without stopping in a flood. if you drive through it fast, it will flood the intake and if you decelerate or release the gas, the rear exhaust will suck in the water either way. that means keep your right foot glued to the gas pedal to about 4000 to 5000 rpm and keep moving by working on the clutch and gears.
Old Aug 1, 2007 | 12:10 PM
VRamirez2004's Avatar
Thats cool I had my car in a flood once when I was in El Paso I had water all the way to my hood vent I saw smoke coming out of it.... I was driving slow through the water the car seemed to stall a little but it kept going all the way home it was a couple of miles like that. I was amazed by how much water there was around...
Old Aug 1, 2007 | 12:20 PM
VtexGt3's Avatar
dang, i'm suprise you didn't lock your engine
Old Aug 1, 2007 | 12:23 PM
Itchy's Avatar
im surprised that you survived this.. yes our cars are meant for rallying but not really rain like this.. are cars are still low to the ground where we could still flood the engine
Old Aug 1, 2007 | 04:13 PM
El.BlueEvo9's Avatar
Put it on a lift and give it a wash.
