crazy problems after turbo install
Old Aug 8, 2007 | 06:58 PM
Dapper Dan's Avatar
ok i just installed my 3076 kit and i srated it up and my idle afrs were like 11.1 and not steady at all. i also swapped my front 02 sensor from an 05 evo during the install. anyways we take it for a test drive and i hit 15 psi and i hit fuel cut. ok now i brought the car back home and my boost gauge only turns on when i have my lights on.....never done that before. i cant figure out what this problem is besides it being the 02 sensor but i know the 02 is good.....any ideas?
Old Aug 8, 2007 | 07:01 PM
CrackerJackToy's Avatar
Why make two posts about the same thing?
Old Aug 8, 2007 | 07:04 PM
Dapper Dan's Avatar
i do
Old Aug 8, 2007 | 07:29 PM
WWNJIX's Avatar
Kinda cryptic???^
Old Aug 9, 2007 | 11:48 AM
Dapper Dan's Avatar
bump
Old Aug 9, 2007 | 06:25 PM
Dapper Dan's Avatar
i need help! ive never been stumped before i just put in a new 02 sensor and it runs the same
Old Aug 10, 2007 | 11:06 AM
Dapper Dan's Avatar
bump
Old Aug 10, 2007 | 12:45 PM
SophieSleeps's Avatar
Not sure why you think it's the 02 sensor.
If you put in bigger aftermarket injectors, how did you compensate for them in ECUflash? Did you change latency as well as injector scaling?
Your boost gauge is wired up incorrectly. Stuff doesn't just change. Someone moved the acc wire to it.
Old Aug 10, 2007 | 12:52 PM
goosey2099's Avatar
Definatly need more info on the setup, but if your guage only turns on or lights up when your lights are on and it never did that before then you blew a fuse somewhere. Get a meter and check every fuse. Post your setup
Old Aug 10, 2007 | 03:39 PM
Dapper Dan's Avatar
i had aftermarket injectors before i installed the turbo and i already tuned my car for them and was running perfect.
and i didnt mess with any wiring at all, all id id was unhook my battery for the install and then hooked it back up afterwards. and yes it is wired up correctly....
i took my car up to my work today and ran a diagnostics check on it and it said it weas the front o2 sensor (but i just put in a new uiniversal bosch) which i heard works fine in our car.......
so is there anything else that could make my car throw an 02 code?
might just have to get a new oem 02 sensor
Old Aug 10, 2007 | 03:43 PM
cpoevo's Avatar
The aftermarket turbo flows a larger volume of air than the stock turbo. You cant just go off of PSI. You will have to retune the car and compensate for the different air flow. I have done 2 different Evos with turbo kits and both had to be totally retuned just to idle correctly. Get the Tactric cable and check your fuel trims and adjust the injectors accordingly.
Old Aug 10, 2007 | 04:10 PM
RussellM's Avatar
Plat Vendor
Just because a part is 'new' doesnt mean it will work. Sometimes it is just a defect or it could have gotten damaged through shipment. You never know.
Old Aug 10, 2007 | 04:39 PM
Dapper Dan's Avatar
are you sure? because according to full race it should idle like stock because at idle it flows the same amount of air...
and im also throwing an 02 sensor code
Old Aug 10, 2007 | 10:50 PM
EVO9_IX's Avatar
did you tune it?
Old Aug 10, 2007 | 10:59 PM
Mines Evo IX's Avatar
I would just use a oem sensor, and check your fuses.
