Radio Not Working After Gauges Installed
Old Aug 11, 2007 | 07:18 AM
hawaiian_evo's Avatar
So i searched throughs 100s of pages looking for my solution
Problem: I installed 3 gauges tapping of the radios power and illumination. After the install I tried to turn the radio on but it didnt work. I didnt check the fuse under the hood yet because i didnt think it would be a fuse problem since the gauges are working good. I thought the stock radio might not be working so i swapped it out with an aftermarket unit from my other car but it's still not turning on. Does anyone know whats wrong?
thanks
Old Aug 11, 2007 | 08:18 AM
diviniti's Avatar
Take the wire tap off, and if it works, you've found your problem.
Old Aug 11, 2007 | 08:22 AM
good idea ill try that> I was hoping it was just the fuse i might have to find a new 12v switch.
Old Aug 11, 2007 | 08:24 AM
turboDan's Avatar
Yes,as sometimes when using wire tap it will actually cut the wire you are tapping into in 1/2 causing this problem.
Old Aug 11, 2007 | 08:26 AM
diviniti's Avatar
Wire taps are easy, but not fool proof. They really cause more problems than help.
Good old fashion wire strippers and some solder go along way.
Or, my personal favorite, wire strippers, solder and heat shrink tubing.
thanks guys ill check and turboDan you may be right I have a feeling I chopped the wire in half but i will check when i get home
