Exhaust manifold removal
Old Aug 11, 2007 | 12:18 PM
Rudager's Avatar
I'm sure this has been talked to death...but can anyone give me tips for removing my exhaust manifold?
I have searched btw
Old Aug 11, 2007 | 12:19 PM
Redline-Z's Avatar
Veteran: Air Force
Yeah, Unbolt it. their is a tech write up on it.
Old Aug 11, 2007 | 12:22 PM
Tsurugi-san's Avatar
You'll have to unbolt the DP, and the rest of the turbo assembly, or you won't have room to slide it off of the bolts.
Bigger job than you think!
Old Aug 11, 2007 | 04:21 PM
SpeedJunkyz's Avatar
plus one, but its fun...... I have had mine off and on like 4 times in the past week LOL ....dont ask....
Old Aug 11, 2007 | 04:24 PM
Johnboy1065's Avatar
its really kind of a ***** to do. but it seems like most of everything on are cars are hard to get to lol
I'd take the DP off. take out the radiator... take all those heat sheilds off. then unbolt it from the head.
Old Aug 11, 2007 | 04:31 PM
mike314's Avatar
1. Unbolt the down pipe
2. Unbolt the manifold from the turbo
3. Unbolt the manifold from the head
4. Unbolt the turbo mounting bracket. its in between the turbo and the block unbolt the bolt holding it to the block the slowly push the turbo assembly down from the top and wiggle the manifold off of the bolts.
Old Aug 11, 2007 | 04:53 PM
1killertsi's Avatar
Turbo mounting bracket bolt needs to be removed.
Old Aug 12, 2007 | 11:46 AM
nk1124's Avatar
even after removing all those bolts it can still be a major pita. I dinged up the radiator pretty good taking it off, id suggest removing that if you feel comfortable doing it, otherwise its a really tight fit getting everything off.
Old Aug 12, 2007 | 11:58 AM
jenx1976's Avatar
use those swivel head ratchet type wrenches....makes it sooooo much easier!!!!
dayvidswrong
Lancer How Tos / Installations
Aug 3, 2015 02:25 PM
91TSiGuy
Apr 7, 2015 06:20 PM
Heezayx
Sep 17, 2013 04:25 PM
euntaeyi
Dec 3, 2011 11:10 AM
DanJ
Sep 15, 2006 06:58 AM
