Plugging a EGT probe
Old Sep 14, 2006 | 03:17 PM
DanJ's Avatar
If for some odd reason I want to remove my egt gauge would I be able to plug the hole in the exhaust manifold with a simple bolt? or is this a bad idea? Would you most likely have to remove the header and have the hole welded?
Old Sep 14, 2006 | 03:26 PM
Bigl4201's Avatar
i would just look for a used one on here
Old Sep 14, 2006 | 03:30 PM
kreionic's Avatar
Are you selling your egt gauge?
Old Sep 14, 2006 | 05:40 PM
2theMAX's Avatar
Yes you can. You need to buy an npt plug from a plumbing store that is the same size and just screw it in. Home Depot has a good assortment.
Old Sep 14, 2006 | 06:54 PM
SlowCar's Avatar
be sure its steel and not brass
Old Sep 14, 2006 | 08:33 PM
DanJ's Avatar
it would be too much work to just put a stock exhaust manifold on just because I have a hole there. I'll stop by homedepot tomorrow and try to find something, thanks.
Old Sep 14, 2006 | 08:42 PM
dubbleugly01's Avatar
1/8" NPT plug will work just fine.
Old Sep 15, 2006 | 06:58 AM
kekek's Avatar
I would try and use stainless steel if you can and also some nickel antiseize. Those should help with corrosion should you ever need to remove it in the future. 1/8 NPT is most likely the size, but make sure you double check with the probe mfg.
If the Depot doesn't have them try www.mcmaster.com
Spish
Jul 29, 2008 01:41 AM
BlackonBlack2
15
Dec 28, 2007 03:11 AM
bigric09
Jul 13, 2007 08:18 PM
Bosshog
32
Sep 5, 2006 11:54 PM
fastevo03
13
Jul 11, 2005 07:36 PM
