removing exhaust manifold studs
Old Sep 12, 2013 | 08:14 PM
Heezayx's Avatar
I am currently installing my map o2 dump and I need to remove the 2 front studs of the exhaust manifold that connect the exhaust manifold to the stock o2 housing.I got the stud to come out a little bit but I don't have much room to work with (using a wrench) anyone have any tips?
Old Sep 12, 2013 | 09:11 PM
Jush's Avatar
I don't recall any studs going between the mani and 02 dump..?
mani -> turbo -> o2 housing
I pulled my turbo out to instal the new o2 housing. Pretty easy just don't round your nuts
Old Sep 12, 2013 | 09:14 PM
Kian's Avatar
The stock bracket?
Old Sep 12, 2013 | 09:37 PM
Heezayx's Avatar
They are the 2 studs on the stock o2 housing closest to the radiator... so they are the studs connecting the manifold to the o2 housing
Old Sep 12, 2013 | 09:45 PM
Kian's Avatar
Lol
Old Sep 12, 2013 | 10:17 PM
adriano_917's Avatar
Its the o2 housing to the turbine not the manifold dude, use lots of Pb blaster. I was able to do it with a ratchet and short socket and the nut on the bottom closest to the block with a wrench from underneath.
Old Sep 13, 2013 | 07:35 AM
ReignMan24's Avatar
^^ Yea let that sh** sit overnite to. Honestly I may have done it the harder way but it seemed easier then gettin my big a** hands in those areas but I just pulled the entire turbo out with the o2 housing connected. Then unbolted it from there.
Old Sep 13, 2013 | 09:45 AM
slipperychicken's Avatar
Lol, I think he means the exhaust housing on the turbo. +2 on the PB Blaster overnight. Breaking off a bolt/ or stud will add more wrench time considerably.
If you choose not to pull the whole turbo with the exhaust manifold, you can also drop the radiator to get more clearance.
Old Sep 13, 2013 | 08:48 PM
iTzMe's Avatar
Bathe in pb blaster leave overnight u should b good if not u have to burn or break
Old Sep 15, 2013 | 09:07 PM
Kian's Avatar
Pull the turbo, it's difficult to tighten the bolts on the back of it next to the block
Old Sep 16, 2013 | 05:14 PM
echofive's Avatar
Definitely easier to do the job with the turbo and dump pipe removed in 1 piece first.
Old Sep 17, 2013 | 04:25 PM
2gsxtasy's Avatar
pb blaster all the way... that's a must for any of those bolts that get CRAZY hot
Lukelis
Feb 15, 2013 05:15 PM
boostnMA
Oct 26, 2012 07:21 PM
88888
Jul 28, 2012 06:25 AM
TakaseEVOIXSE
22
Feb 5, 2011 06:34 PM
silver05evo8
27
Feb 21, 2010 03:18 PM
