is it safe
Old Aug 21, 2007 | 04:46 PM
evo8nyc's Avatar
is it safe
im running 23 pounds on my IX with a tune TBE, fuel pump, intake should i lower the boost or is this Okay. Its daily driver as well.
Old Aug 21, 2007 | 04:48 PM
Rudager's Avatar
gonna get flamed for not searching
it's prolly ok as long as you have 93 octane
evo8nyc's Avatar
yea im on 93 and thanks
Old Aug 21, 2007 | 04:51 PM
sabastian458's Avatar
dude, that's fine.
Old Aug 21, 2007 | 05:20 PM
El.BlueEvo9's Avatar
I use to run 25lbs on pump and only pump with a flash & no Knocks .
Old Aug 21, 2007 | 06:02 PM
JDMCT9MR's Avatar
Good to go!
Old Aug 21, 2007 | 06:10 PM
sikrsix's Avatar
Why would you alter your car after you just paid for it to be tuned???
Old Aug 21, 2007 | 06:15 PM
evo8nyc's Avatar
wanted to know if it safe
Old Aug 21, 2007 | 06:18 PM
tripperfx3's Avatar
If you were tuned for 23 than you should be fine, but if you were not id turn it down to where it was for the tune. You may actually be making less power or getting some knock. Some tuners like to advance timing to get power some increase the boost. Id do some logs and make sure your not getting any knock.
Old Aug 21, 2007 | 07:35 PM
evo8nyc's Avatar
well sean ivey tuned me for 23 pounds so i donno ill do a log just to be sure
Old Aug 21, 2007 | 08:12 PM
sikrsix's Avatar
If he tuned you, your all set.. Think he would set your car up to need a new motor?? I think not..
Old Aug 22, 2007 | 06:50 AM
Chemwarrior's Avatar
I'm tuned for 23 psi using 93 octane with about the same mods and have zero problems.
Old Aug 22, 2007 | 07:15 PM
DBPLAYA00's Avatar
from the searches i have read u should be good on 93 octane and good tune.
Old Aug 23, 2007 | 12:16 AM
erioshi's Avatar
I will add this: It depends on how hard you drive the car. While that figure is considered safe and I drove my car that way for about 35K miles, eventually I had the #1 rod bearing fail. Luckily in my case it didn't put the rod through the side of the block.
My car had seen alot of track use, dyno time, etc. And when it did fail the bearing spun at low boost (about 7 psi) while going up a very slight hill cruising 70 mph on the freeway. The post-mortum revealed that the stock connecting rod bolts had stretched on the #1 rod leading to the failure.
My car had seen lots of hard use, but there is plenty of good evidence showing that increased performance is paid for with shortened engine life. On my car everything looked solid & ran well right up until the bearing spun - no warning.
Old Aug 23, 2007 | 12:21 AM
Happy Hazard's Avatar
Stretching would indicate overrev on the conrod, not too much boost. If your cylinders didnt show signs of detonation or cracked pistons/skirts then you probably bounced off the rev limiter too many times or all that track/dyno time was spent at 5k+
