Evo Badge Removal
Old Sep 9, 2007 | 08:01 PM
KS_Evo9's Avatar
Evo Badge Removal
So I searched and can only find how to remove the rear badge that says Lancer Evolution. Im wanting to remove the on the front bumper. Do I have to remove the bumper to remove this badge? Help/Info will be appreciated
Old Sep 9, 2007 | 08:08 PM
Tsurugi-san's Avatar
Yes, it will be easier for you to just remove the front bumper (trust me, it's WAY easier than you think). After you're done with it the first time, you'll see that as soon as you remove the pop rivets for the undertray, it's only a 5 minute job. The badge should be a no-brainer from there. Just remember that there's an indention/hole in the mesh under the emblem --- you might want to hide that somehow.
Good luck!
Old Sep 9, 2007 | 08:15 PM
Corey's Avatar
To remove the "Lancer Evolution" badge, just use some fishing line and run it behind the badge slowly. If there is any stickiness afterwards, just use some wax and it'll come off with some rubbing. That was my first mod to my car the day I brought it home.
Old Sep 9, 2007 | 08:17 PM
DeeezNuuuts83's Avatar
^ Obviously you didn't read the guy's post.
Old Sep 9, 2007 | 09:06 PM
fox2boost's Avatar
i was gonna ditch my badge completely but after taking it off and having that bracket there i just decided to flat black it. If i really wanted to i could have cut the bracket off bu i just dont wanna start hacking up my 30k car. The bumper is def a little intimidating at first but once you find out you dont have to take the whole undertray off its cake.
Old Sep 9, 2007 | 09:10 PM
Corey's Avatar
No actually I did read his post, but just misread it. I guess I read the first sentence too fast. Oh well...
Old Sep 9, 2007 | 09:14 PM
KS_Evo9's Avatar
Dang so I gotta take the bumper off that sucks cause im no body man. Ill be so mad if I took it off and put it on and it didnt aline perfectly best bet is just to leave it I guess.
Old Sep 9, 2007 | 09:34 PM
^ Yeah, I'd leave it. Personally, I think the front end looks a little odd without the emblem. It usually looks best if a grille is debadged when it's a framed grill, like how some Impreza and Civic grille replacements are.
Old Sep 9, 2007 | 09:39 PM
I'm tellin' ya ----
ramps to get nose in the air, check
socket set with extension for IC side bolts (2) fender side bolts (2) & top bolts (2?), check
reg. screwdriver & needle nose pliers for underhood push clips (2), check
phillips screwdriver for undertray & intake scoop pop rivets, check
phillips bit for fender liner screws (2), check
guts to grip the bumper and yank that beeotch off, check
or . . . just read the how to --- it really is easy (and fun)!
Go for it!
Old Sep 9, 2007 | 09:49 PM
KS_Evo9's Avatar
HAHAHA
Old Sep 10, 2007 | 06:09 AM
Dont Try To Run's Avatar
you gotta learn sometime bro
Old Sep 10, 2007 | 01:50 PM
Positron's Avatar
You can remove the front emblem whenever you take off the bumper to install a LICP =P
Old Sep 10, 2007 | 02:50 PM
Neuspeed06's Avatar
I tried the fishing line method, it kinda worked, but that glue stays on there. I had to use tar remover to get it all off.
Old Sep 11, 2007 | 02:39 AM
Corey's Avatar
I did it when the car had sat in the sun for a while and did it VERY slowly. I didn't have hardly any stickiness to take off.
