catalyst rattle?
Old Sep 10, 2007 | 02:29 PM
sl0ev0's Avatar
catalyst rattle?
about 6 months ago i put on a downpipe and high flow cat, and i had a little rattle on the lower crossbar.
after a while it started rattling a lot more, i'd say for the past 2 or 3 months. i just thought it was hitting the ACD so i never really looked at it, it didn't bother me too much, but now it does.
so i went under and found that it was rattling from the cat, and there is nothing the cat is hitting. has anyone ever had a problem with the catalyst inside of the cat getting loose and rattling? i think thats what it is...
Old Sep 10, 2007 | 02:46 PM
Neuspeed06's Avatar
I had the same rattle.......it was hitting the ACD.......so i modified the DP alittle by banging it in somewhat. NOw i have no rattle. Also did u secure the harness for the O2 wire?
Old Sep 10, 2007 | 02:59 PM
evo150's Avatar
make sure the o2 sensor isnt rubbing the undercarriage.
Old Sep 10, 2007 | 03:02 PM
sl0ev0's Avatar
its definitly not the ACD, its coming from the cat
i glanced at it and i am pretty sure it isnt hitting, but it might be there. i did do the o2 cheater with the spark plug non-foulers, so its possible. i'll check soon
Old Sep 11, 2007 | 05:46 AM
topnitroracer's Avatar
I had the same rattle and it was driving me crazy. It would only happen every so often and mostly after the car had warmed up for a bit and it was just idling. You could also only hear it from inside the car which was weird. I had checked everywhere and it was not touching anything. When I finally removed my hfc to install my resonated test pipe I discovered the catalyst had broken free from the housing. You would shake it and it would make a clunk. So yes you could have the same exact problem which is apparently very common with catco items (company which manufactures a lot of catalysts). Catco blames it on rich conditions in the exhaust which cause micro explosions in the cat which beak it catalyst free. I call it a cheap and poor design. I first heard my cat rattle about 4.5 weeks after installation (I was still on the stock rich tune then). I hope this helps.
Old Sep 11, 2007 | 06:07 AM
alicea8541's Avatar
I had the same problem and just as it got to the point of annoying the crap out of me, it stopped. I had just been talking to a local guy and he said he would be able to stop the rattling and a couple of days before I took it to him the noise went away and never came back.
Old Sep 11, 2007 | 06:54 AM
zwickyc's Avatar
Sounds like the exact same rattle I had which led to my catalyst being replaced under warranty. No problems since.
Old Sep 11, 2007 | 07:06 AM
sl0ev0's Avatar
*%$@. looks like im getting a test pipe
Old Sep 17, 2007 | 05:46 PM
sl0ev0's Avatar
yep. got the test pipe today. the catalyst is shot in the hfc
Old Sep 17, 2007 | 06:04 PM
BBS's Avatar
BBS
Which hfc did you purchase so I don't purchase the same one. Cats shouldn't dislodge for atleast 75-100k miles.
Braydo25
Lancer Troubleshooting
Aug 15, 2015 07:54 PM
Cedricredrs
May 20, 2007 03:09 PM
az_evo_mr
Apr 11, 2007 05:32 PM
671
Jul 30, 2006 05:17 PM
jdizzy
Jun 6, 2005 02:21 PM
