race gas question
Old Sep 15, 2007 | 02:37 PM
bluebyu36's Avatar
so i need a tatrix cable and a lab top
Old Sep 15, 2007 | 02:39 PM
kreionic's Avatar
Ding ding.
Or I dont know much about the cobb access port. I believe you can have 2 or so maps on there without a laptop or tactrix but its expensive
Old Sep 15, 2007 | 02:40 PM
bluebyu36's Avatar
how much is the cable???
Old Sep 15, 2007 | 02:43 PM
kreionic's Avatar
http://www.tactrix.com/product_info....91c947203b01e6
Old Sep 15, 2007 | 02:44 PM
bluebyu36's Avatar
dam it's cheap, so now let me get this straight with that cable and labtop i could have sean ivey tune 2 maps one for pump gas and one for race gas.
Old Sep 15, 2007 | 03:38 PM
psphinx81's Avatar
yes
Old Sep 15, 2007 | 04:25 PM
uSmC_08's Avatar
Don't forget to download ECU Flash and Mitsulogger or EvoScan
Old Sep 15, 2007 | 04:26 PM
bluebyu36's Avatar
thanks fellas
Old Sep 15, 2007 | 04:28 PM
uSmC_08's Avatar
thanks fellas
Let me know how it goes, because I'm thinking of getting a race gas flash as well
Old Sep 15, 2007 | 08:02 PM
kouzman's Avatar
if you run straight or almost straight racegas and especially more than 105-108 octane the car probably will run slower... mine did!
now if you tune on a specific racegas then the car will be faster...
If you use a racegas mix just to bring the octane level 2-3 numbers more then you run run a bit more boost and make more power...
Old Sep 15, 2007 | 08:19 PM
BGevoIX's Avatar
Race gas
I saw this in person...
A co-worker had a SRT4 with a 2.6 stroker motor and 60-1 turbo. At 22 psi on 91pump gas (partially tuned, running low timing) he made 442 whp. After adding 100 octane, no more boost and no adjustments to the tune, he made 484 whp. But it does burn slowly and it is definately best to have a map that you can swap into your ECU for race gas due to the fact that it does burn slower.
Old Sep 15, 2007 | 08:26 PM
kouzman's Avatar
well i should note that my "test" was made with leaded Sunoco 116 octane... Maybe if i had used 100-103 unleaded the car would respond better...
Old Sep 15, 2007 | 08:40 PM
evo_08's Avatar
you can go up quiet a bit just with timing alone @ the same boost.
Old Sep 16, 2007 | 06:40 AM
ttbestas's Avatar
half the people i ask tell me that i will gain power from putting in race gas, and turning up the boost.Then the other half tell me i will lose power because i am not tuned for it.what is the real answer?i have a fully built block with a white rabbit tme turbo but im tuned for pump gas...can i run 27 28 pounds on race gas safely?or am i losing power?thanks.....
tune it first....
Old Sep 16, 2007 | 11:24 AM
stefano's Avatar
you might as well just get dedicated pump octane and race gas maps since it's so easy to flash between the two. i never did trust putting a few gallons of race gas in and turning up the boost. you'll either be leaving HP on the table or running lean.
