car kill switch
Old Sep 13, 2007 | 03:49 AM
chrismnj's Avatar
Question car kill switch
does anyone has a kill switch ? how do u do it ?
Old Sep 13, 2007 | 03:51 AM
sharkm87's Avatar
wouldn't it just tie into the ignition harness??
Old Sep 13, 2007 | 03:56 AM
chrismnj's Avatar
anybody has a diagram how to ?
Old Sep 13, 2007 | 04:08 AM
turboDan's Avatar
Easiest way would be to disable fuel pump.Just make sure you do not put switch in a place like under the dash,put in a harder place to find. Over 50% of car breakins/ thefts are by someone who KNOWS you.If they know you have a switch to kill power to fuel pump you might as well not even put one in
Old Sep 13, 2007 | 01:33 PM
chrismnj's Avatar
anybody has a diagram how todo it fuel pump or ignition kill switch ?
Old Sep 13, 2007 | 06:01 PM
Robevo RS's Avatar
i have a battery kill switch.
Old Sep 13, 2007 | 06:30 PM
Marc Hatzi's Avatar
Are these cars able to be hotwired? I know it is impossable to drive a SRT4 (my last car) without the key. I would have thought all cars would have this type of feature now.
Old Sep 13, 2007 | 08:16 PM
gsrboi80's Avatar
Just put a switch in line to the power to your fuel pump. Or go on Honda-Tech and search around. Hondas guys layer security thick man. We have to
Old Sep 13, 2007 | 08:20 PM
red evo8's Avatar
easiet way would be to what run a switch extended to the back rear seat to the main fuel pump power wire , i think that would drain voltage going to the fuel pump if some one knows a closer location of the fuel pump possibly under the dash or off one of the main harnesses
Old Sep 13, 2007 | 10:04 PM
TempeRacerGuy's Avatar
Why are you in need of a kill switch? The Evo cannot be hotwired, and no one can start your car without the key matched to the ECU.
Old Sep 14, 2007 | 08:46 AM
Wallesasuaz's Avatar
They'll bring their own ECU and match it w/ the KEY and they out.
So many evos' have been stolen.
Old Sep 14, 2007 | 08:56 AM
Marc Hatzi's Avatar
Wow, never knew that.
Old Sep 14, 2007 | 08:58 AM
MyEvoDream's Avatar
on my gti I had one...even if you put the key in to start it and didnt flip the switch, wouldnt start...I think we just did it to the ignition wire
Old Sep 14, 2007 | 09:17 AM
tweakdsm's Avatar
dont tell anyone wheres the kill switch Fuel pump kill switch is the way to go!
Old Sep 14, 2007 | 09:25 AM
Yimke's Avatar
Just put a switch in line to the power to your fuel pump. Easy, inexpensive, and effective. I would probably mount the switch in an ashtray if you don't smoke. Otherwise under the dash. Somewhere out of plain sight but easy to reach if you're getting out of the car.
BTW it IS Possible to steal the SRT-4 w/o a key. If man can build it. It can be unbuilt.
