are cam gears nessecary?
Old Sep 14, 2007 | 01:05 PM
Kevin Knight's Avatar
Im getting a AMS FMIC , hks 272 cams and new spark plugs with apr head studs. so is cam gears nessecasry? also do i need to get new valves and retaniers? thanks
Old Sep 14, 2007 | 01:08 PM
laakness's Avatar
cam gears are not necessary, only if you want the ability to adjust your powerband around. A lot of auto x guys like them since they can move the power to lower rpms
Old Sep 14, 2007 | 01:10 PM
Kissandtell's Avatar
I have HKS 272's and did not upgrade my valvetrain. The source I used to determine whether or not I had to was:
https://www.evolutionm.net/forums/sh...d.php?t=123216
Old Sep 14, 2007 | 01:25 PM
Warrtalon's Avatar
Yes, you need all of those things.
Old Sep 14, 2007 | 02:54 PM
1QYK9's Avatar
Aren't you able to (at least on a IX) adjust the cam angles via ECU tuning? If this is the case, it wouldn't seem like you would need adjustable cam gears because you can adjust the angle via the ECU.
Old Sep 14, 2007 | 02:55 PM
kreionic's Avatar
On the intake cam on the 9 yes but not the exhaust cam. The OP has an 8 though
Old Sep 14, 2007 | 02:59 PM
mplspilot's Avatar
You need cams, plugs and fmic. The rest you don't.
Old Sep 14, 2007 | 03:04 PM
Cali2MDevo8's Avatar
Registered User
GSC S1's.........no cam gears for me!
jason
Old Sep 14, 2007 | 04:18 PM
1QYK9's Avatar
Thanks for the clarification! So, cam gears are normally sold in a set. For a IX, you'd install both set of cam gears, but only adjust the exhaust cam gear by hand because you will adjust the intake cam by the ECU, correct?
Old Sep 14, 2007 | 07:23 PM
krazirob's Avatar
if you think you know how to install then dont. take it somewhere and make sure it gets done properly. when they are adjusted properly then you will make some great power....
Old Sep 14, 2007 | 09:18 PM
Whoop_ass's Avatar
Why do people not search!!
you learn so much more when you search
I agree with warrtalon here buy 2 cam gears and put them on your 9.
bahhhhh who need MIVEC
Old Sep 14, 2007 | 09:39 PM
BBS's Avatar
BBS
DAMN! I wanted to ibtw.
Old Sep 14, 2007 | 09:44 PM
Blue Evo 8's Avatar
Yes they do help......
plus they look bling......
Old Sep 14, 2007 | 09:48 PM
1QYK9's Avatar
Very nice!
Old Sep 15, 2007 | 05:22 AM
gsrboi80's Avatar
BC 272s no cam gears here
I have Springs, Retainers and Headstuds though
