Forge MBC
Old Sep 20, 2007 | 06:09 PM
augosta's Avatar
Forge MBC
Hi to all
I just had installed Forge MBC in my EVO IX, the installed spring is the soft one but even if I turn the boos to maximum still the boost goes no more than 17 psi on my AEM boost gauge.
Do you think that I have to put the heavy spring to have more boost?
Thanks
Old Sep 20, 2007 | 06:25 PM
Evo_Jay's Avatar
yes
Old Sep 20, 2007 | 06:26 PM
Kerr's Avatar
Fomer Vendor
Did you make sure you installed it correctly? I vote to double check the vacuum lines first. I helped a friend install the same MBC on his 9 and his soft spring is boosting 25 psi (not maxed).
Old Sep 20, 2007 | 06:31 PM
Chukee_R's Avatar
Soft spring should hold more than that. Double check everything. I put the hard spring in my Forge MBC (when I had it) and it hit 28psi on the lowest setting.
Old Sep 20, 2007 | 06:38 PM
4g63_24's Avatar
When I installed my forge mbc, the soft spring hit 21 PSI and that wasn't even turn all the way up... I believe the soft spring is the one that comes already inserted inside the mbc...or I could be wrong...
Old Sep 20, 2007 | 08:04 PM
rocket900rr's Avatar
With my stiff spring the lowest I can boost is 23 lbs. I dont have a problem boosting about 31 lbs. with about 14-16 clicks open.
Old Sep 20, 2007 | 08:06 PM
jrsimon27's Avatar
i have 55clicks for 22psi of boost but iam at 3300'feet above sea level
Old Sep 21, 2007 | 09:19 AM
patty AT forge's Avatar
Soft comes pre-installed.
Old Sep 21, 2007 | 10:52 AM
NYEvoguy's Avatar
Check your lines.
Old Sep 21, 2007 | 12:00 PM
97TSiAWD's Avatar
I'm using the soft spring and have run up to 22psi, and still haven't had the MBC fully adjusted. I would check your lines and, if those are fine, check that the spring is properly seated in the boost controller.
Old Sep 21, 2007 | 12:09 PM
Evo_Jay's Avatar
One thing that no one has mentioned is that there is two sets of springs that come with the forge. On the earlier set, you need to run the hard spring to get 22lbs. On the later (newer) set, you can achieve 22lbs with the soft spring.
Is it new or used?
Old Sep 21, 2007 | 12:22 PM
Evo Tengoku's Avatar
Yes. I am boosting 25psi on the soft spring. (not maxed)
The hard spring at the lowest setting spiked over 25psi.
Old Sep 21, 2007 | 01:34 PM
Evo_Jay's Avatar
hey read this about breaking in the hard spring.
https://www.evolutionm.net/forums/sh...d.php?t=259636
Old Sep 21, 2007 | 06:58 PM
augosta's Avatar
OK I just but the hard spring in and the boost spike 26 lb at lowest setting
I think the soft spring was not installed properly, so I will put it back and check
4g63kid
22
Jan 24, 2012 08:18 PM
ibarkovic
26
Jan 16, 2009 07:03 AM
MRevolutionRed
Jul 1, 2007 03:57 PM
blackonblackevo
227
Jun 26, 2007 03:54 PM
PEARLEVOIXMR
30
May 16, 2007 06:24 PM
