Oil Filter
Old Sep 21, 2007 | 12:11 PM
  #31
gsrboi80's Avatar
The regular frms are crappy. However I use the Fram X2 which is one of the best filters on the market. 80k strong now
Old Sep 21, 2007 | 01:01 PM
  #32
DSMEVOLUTION's Avatar
Originally Posted by Cal City Evo
Ok I'm going to pin head Fram!!! 65K and no problems. FWIW you have a gigantic lack of knowledge.
I have most likely been changing oil longer than you have been alive and have NEVER had an issue with one of these filters. What part of OEM replacement don't you understand there bed wetter????
If you don't mind getting *** raped go ahead and pay more for the same thing.
End of rant.
Wow, that was a worthless post. You say your so old, then start acting like it. I know 15 year olds with more maturity. It bad when you have to state your age to compensate for the lack pure knowledge.
Getting back on topic. There are alot of good filters out there but I only use the oem filter. I've been using them since I had my 1995 GST. Don't want to screw up a good thing.
Old Sep 21, 2007 | 02:25 PM
  #33
derangedazn's Avatar
End of rant.
"You need to grow up.....And btw you're ghey."
Old Sep 21, 2007 | 04:45 PM
  #34
urslo4n8's Avatar
HA! OH NOOOOOO ^^^^^^^^^ Its Dr. Phil now youre in some serious trouble.
Old Sep 23, 2007 | 01:23 PM
  #35
bigpzz's Avatar
cracked oil filter
I had a k&n filter and while pushing it, I think a rock flew and caused a crack in it. has anybody ever had this problem. Oil just started leaking everywhere. Damn. Hate where they placed the oil filter.
Old Oct 23, 2007 | 09:42 AM
  #36
hytek369's Avatar
where do people get the replacement washers? i think it comes with the oem filter, but where would you get it if you got an aftermarket.
Old Oct 23, 2007 | 09:55 AM
  #37
spumoni1984's Avatar
the copper washer that seals around the pan hole??- i only replace mine every 3rd oil change...i just asked if they had any seals at advanced or pep boys.
Old Oct 23, 2007 | 10:01 AM
  #38
tweakdsm's Avatar
why spending time and thinking, what filter to choose, just go to mitsu, and get oem one. I usualy buy few so i get a discount
Old Oct 23, 2007 | 10:02 AM
  #39
barneyb's Avatar
I have been driving Mitsu's powered by the 4g63 since 1992 and I have yet to use a replacement washer. No leaks. So, here is one course you might follow to solve the after market oil filter washer problem.
Old Oct 23, 2007 | 10:48 AM
  #40
MalibuJack's Avatar
Although I don't have a bias on the type of filter, their all not the same.. less restriction may also mean less filtration, either because they have less filtration or a bypass valve.
I did want to add that I just had an oil filter get damaged by something hitting it while driving. I would definitely recommend against putting anything on there that hangs down any lower than the stock one.
Old Oct 23, 2007 | 10:49 AM
  #41
MalibuJack's Avatar
I had this happen to an OE filter this past week.
Old Oct 23, 2007 | 10:53 AM
  #42
ohEVO18's Avatar
K&N or Mobile 1 if the parts store doesnt have it...
Old Oct 23, 2007 | 11:50 AM
  #43
kingman4's Avatar
Malibujack, which brand filter do you normally use? OEM or some 3rd party?
Old Oct 23, 2007 | 12:08 PM
  #44
W0459732's Avatar
OEM, ive heard k n N is good also
Old Oct 23, 2007 | 12:10 PM
  #45
MalibuJack's Avatar
OE, I've had some bad experiences with aftermarket filters over the years, nothing really worth noting, but OE is OE for a reason.
