hard intake pipe with stock airbox
Old Sep 22, 2007 | 06:33 PM
RedLanEVO's Avatar
anyone tried using the rmr hard induction pipe, or any hard intake pipe with the stock airbox? (basically RMR & Ralliart) i am planning to use one with my stock airbox only because i BELIEVE my stock rubber intake pipe is collapsing on me everytime it hits full boost (23psi). had LSE performance do a leakdown and boost leak test, everything was good. still have that major boost taper so i am thinking this is the problem. going to try it anyways, but just want your word on it. i've tried looking on here for someone who has tried it, but no luck.
Old Sep 22, 2007 | 07:51 PM
mhgsx's Avatar
I ran the Cusco hard pipe with the stock airbox. It fit with no problems. Also the Samco induction pipe works, too.
I have both available if you're interested, just pm.
Old Sep 22, 2007 | 10:03 PM
Boltz.'s Avatar
FCOTM Winner
Don't waste your money, your making some big leaps from a shop telling you you don't have a boost leak to you thinking your intake pipe is collapsing. Unless you've personally watched your intake pipe collapse(like on a dyno) I'd bet the house its fine.
Instead you should be asking about your boost taper problem...
Old Sep 23, 2007 | 08:48 AM
dsmfan95's Avatar
I highly doubt you're collapsing the stock pipe. I ran mine on the Green and high boost with no problems.
I would look into switching out the stock air box. I noticed an increase of boost at redline once I finally switched mine out.
Old Sep 23, 2007 | 10:18 AM
RedLanEVO's Avatar
thanks guys, but i've already ordered the rmr pipe. after i ordered it, i took the car out for a spin and to a surprise, taper isn't as bad anymore. spikes and falls a couple psi according to my gauge. i usually had it spike and fall 6-7 psi. have no idea why.
germanmike954
Jan 9, 2017 12:21 PM
breadn56
Sep 28, 2015 06:41 PM
Brandisher
Aug 18, 2014 10:43 AM
D1andonlyantman
34
Jun 26, 2014 07:29 AM
ghad
Oct 24, 2013 11:29 PM
